I just upgraded to 18.04 and I'm loving the new look but I'm horrified to discover that all of my customizations added by CompizConfig Settings Manager aren't working!
I've tried uninstalling & reinstalling compizconfig-settings-manager, and moving the ~/.compiz folder to try to get it to reset, but that's not helping. It's clearly not that it's lost my settings so much as that it's not connected to whatever it's supposed to affect.
e.g. if I reset the settings and then try turning on Firepaint just as a test, nothing happens when I press the Firepaint shortcut..
I'm about to try restarting (now that I've uninstalled & reinstalled ccsm) to see if that helps. UPDATE: Restarting didn't help.
Before you begin, please enable the Universe repository.
Unfortunately, 18.04 uses Gnome Shell instead of Unity and so Compiz doesn't work.
Fortunately, you can install the old Unity based Ubuntu desktop by running the following commands:
sudo apt update
sudo apt install ubuntu-unity-desktop unity-session unity-greeter
This will also install a lightdm session manager which will give you the more familiar login experience. When prompted, select lightdm from the list of session managers to replace the now default gdm session manager.
If you do not see that option, please run the following command to switch to lightdm:
sudo dpkg-reconfigure lightdm
and then select lightdm when prompted.
For a full list of additional packages like unity scopes and lenses, run the following command:
apt-cache search unity | grep -P '^unity'
Now, reboot and make sure to select the Unity session by clicking on the icon to the left of the login box when you log back in.
After you log back in, the CompizConfig Session Manager will work just like it used to.
mchid
  • 44,904
  • 102
  • 162
