I'm running some scripts to check the UFW status and would like to run sudo ufw status without having to do sudo. I was hoping to find a firewall or ufw group to add myself to, but I didn't find any.
How can I allow any user X to do the ufw status without being root or asking for sudo password?
UPDATE:
I wanted to try to add my own file to /etc/sudoers.d/, but was lazy so decided to copy one already existing, like this:
sudo cp /etc/sudoers.d/mintupdate /etc/sudoers.d/firewall_status
Don't do That! You will not be able to do sudo or login again. I had to do a boot recovery. Instead use:
sudo visudo -f /etc/sudoers.d/ufwstatus
Now just follow the accepted answer below.
not2qubit
  • 616
Here's an /etc/sudoers.d/ file that works for me:
$ sudo cat /etc/sudoers.d/ufwstatus
Cmnd_Alias      UFWSTATUS = /usr/sbin/ufw status
%ufwstatus      ALL=NOPASSWD: UFWSTATUS
Then add the new "ufwstatus" group (here added as a system group):
sudo groupadd -r ufwstatus
Your otherwise non-privileged user must be added to the ufwstatus group e.g.
sudo gpasswd --add testuser ufwstatus
In order for the change to take effect, the user needs to log in again:
su - testuser
Then
testuser@xenial-vm:~$ sudo ufw status
Status: active
To                         Action      From
22/tcp                     ALLOW       192.168.1.0/24
3389/tcp                   ALLOW       192.168.1.0/24
111                        ALLOW       192.168.1.0/24
2049                       ALLOW       192.168.1.0/24
but other ufw commands are disallowed (even slight variants, such as status --verbose):
testuser@xenial-vm:~$ sudo ufw status --verbose
Sorry, user testuser is not allowed to execute '/usr/sbin/ufw status --verbose' as root on xenial-vm.
testuser@xenial-vm:~$ sudo ufw disable
Sorry, user testuser is not allowed to execute '/usr/sbin/ufw disable' as root on xenial-vm.
not2qubit
  • 616
steeldriver
  • 142,475
