-1
gokulraj@optimus-prime:~$ sudo apt install default-jdk
E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
The error is occured.
PerlDuck
  • 13,885
There are 2 possibilities;
  1. You may be currently running another process with apt, if this is the case, you can wait for it to complete, another option is to simply kill the process.
  2. A previous process (e.g. when apt was executed in the past) did not delete the lock file, this file would exist in /var/lib/dpkg/lock-frontend, then if there wasn't a process using it at all, you would have to remove it manually with sudo rm /var/lib/dpkg/lock-frontend, then force package reconfiguration with sudo dpkg --configure -a
