This PC (Dell Optiplex 755) is running Ubuntu 16.04. A week ago, I tried to upgrade to 18.04, but it failed with the "Aborting. Restoring Original state" message. Ever since then, Software Updater has failed, with errors like E: Internal Error, No file name for libc-bin:amd64. (Several other packages updated successfully.) It all worked perfectly before the upgrade attempt. My most recent attempt to fix things went as follows:
$ apt-get download libc-bin
$ sudo dpkg -x libc-bin*.deb /
$ sudo apt-get install --reinstall libc-bin
Reading package lists... Done
Building dependency tree
0 to upgrade, 0 to newly install, 1 reinstalled, 0 to remove and 3 not to upgrade.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
I also tried "sudo dpkg --configure -a" based on other threads here. That also errors:
~$ sudo dpkg --configure -a
Setting up libc-bin (2.23-0ubuntu10) ...
Bus error (core dumped)
/sbin/ldconfig.real: Can't stat /lib/i686-linux-gnu: No such file or directory
/sbin/ldconfig.real: Can't stat /usr/lib/i686-linux-gnu: No such file or directory
/sbin/ldconfig.real: Path `/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: Path `/usr/lib/x86_64-linux-gnu' given more than once
/usr/lib/x86_64-linux-gnu/libfakeroot:
    libfakeroot-0.so -> libfakeroot-tcp.so
/lib/i386-linux-gnu:
dpkg: error processing package libc-bin (--configure):
 subprocess installed post-installation script returned error exit status 135
 libc-bin
My goal is not to upgrade to 18.04, but just to get 16.04 working again.
OptiPlex-755:~$ apt-cache policy libc-bin:amd64 libc6:i386
libc-bin:
  Installed: 2.23-0ubuntu10
  Candidate: 2.23-0ubuntu10
  Version table:
 *** 2.23-0ubuntu10 500
        500 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages
        100 /var/lib/dpkg/status
     2.23-0ubuntu3 500
        500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
libc6:i386:
  Version table:
        500 http://us.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages
        500 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages
     2.23-0ubuntu3 500
        500 http://us.archive.ubuntu.com/ubuntu xenial/main i386 Packages
OptiPlex-755:~$ dpkg -S /lib/i386-linux-gnu
libuuid1:i386, libc6:i386, libsystemd0:i386, libpng12-0:i386, libglib2.0-0:i386, libncurses5:i386, libusb-1.0-0:i386, libjson-c2:i386, libgcrypt20:i386, libcomerr2:i386, libgcc1:i386, libpcre3:i386, libselinux1:i386, libtinfo5:i386, libgpg-error0:i386, zlib1g:i386, libexpat1:i386, libdbus-1-3:i386, libudev1:i386, libssl1.0.0:i386, libbsd0:i386, libcap2:i386, libwrap0:i386, libkeyutils1:i386, liblzma5:i386: /lib/i386-linux-gnu
OptiPlex-755:~$ grep -r 86 /etc/ld.so.conf.d
/etc/ld.so.conf.d/i386-linux-gnu.conf:/lib/i386-linux-gnu
/etc/ld.so.conf.d/i386-linux-gnu.conf:/usr/lib/i386-linux-gnu
/etc/ld.so.conf.d/i386-linux-gnu.conf:/lib/i686-linux-gnu
/etc/ld.so.conf.d/i386-linux-gnu.conf:/usr/lib/i686-linux-gnu
/etc/ld.so.conf.d/fakeroot-x86_64-linux-gnu.conf:/usr/lib/x86_64-linux-gnu/libfakeroot
/etc/ld.so.conf.d/x86_64-linux-gnu.conf:/lib/x86_64-linux-gnu
/etc/ld.so.conf.d/x86_64-linux-gnu.conf:/usr/lib/x86_64-linux-gnu
OptiPlex-755:~$
OptiPlex-755:~$ sudo ldconfig --verbose
Maybe this can help
How to get software updates working in 16.04? It broke after a failed upgrade to 18.04
sudo apt-get install --reinstall ./libc-bin*.deb
