My partitions
I erased my whole disk and now I only have Ubuntu but I need a windows now so I made a bootable windows 10 usb and I started on legacy boot but computer directly open the Ubuntu. Can you help me please
Update: I installed Ubuntu again in UEFI mode and made my disk GPT but still same thing is happening. See my partitions above.
Zanna
  • 72,312
CCelik
It sounds like the issue is that you can't boot from the USB itself. If you are spamming the correct key to view the boot options when the computer turns on you should be able to select your flash drive as the boot option.
On most laptops and pcs to view the boot options you have to spam either F9 or ESC as the computer boots up to view the boot options.
If you erase whole disk it is possible that your disk is now converted to mbr. In order to install uefi version of windows which happens when you boot from a usb, you need change partition table of your entire disk to gpt. Hope it will help.
Adit
