I can't get rid of a proxy configured in Ubuntu 16.04.
I have tried the solutions suggested here, but did not resolved my situation:
How to permanently disable http_proxy
How to disable proxy in Ubuntu 16.04 LTS
How to remove proxy permanently from ubuntu>
The command env | grep proxy return nothing.
The network setting GUI is configured to None and Applied system wide.
I have removed the line of the proxy from /etc/apt/apt.conf, now is empty. Already rebooted the system (note: shut-down then power on, not just pressed reboot).
I have removed git and installed again but no luck.
If try to clone a repository from git, i still get errors because of the system is trying to connect to the proxy (i have not copied the github url and proxy ip in clear):
git clone https://github.com/xxxxxxx/xxxxxxx.git
Cloning into 'xxxxxxx'...
fatal: unabke to access 'https://github.com/xxxxxxx/xxxxxxx.git/': Failed to connect to XXX.XX.XXX.XXX port 8080: Connection timed out.
I i run apt command, for example apt-get update it does not try to connect to the proxy, and work properly.
How can i remove this proxy? Thank you
The command git config -l returned:
http.proxy=http://@xxx.xxx.xxx.xxx:8080/
http.proxyauthmethod=basic
http.sslverify=false
So it's a git specific proxy. Resolved by the command:
git config --global --unset http.proxy
Now git config -l return:
And git clone works properly.
