I was following the answer on: How can I install protoc on Ubuntu 16.04?
But, my protobuf installation make fails with versioning issue in Automake
/protobuf/missing automake-1.15 --foreign
configure.ac:48: error: version mismatch.  This is Automake 1.15,
configure.ac:48: but the definition used by this AM_INIT_AUTOMAKE
configure.ac:48: comes from Automake 1.15.1.  You should recreate
configure.ac:48: aclocal.m4 with aclocal and run automake again.
WARNING: 'automake-1.15' is probably too old.
         You should only need it if you modified 'Makefile.am' or
         'configure.ac' or m4 files included by 'configure.ac'.
         The 'automake' program is part of the GNU Automake package:
         <http://www.gnu.org/software/automake>
         It also requires GNU Autoconf, GNU m4 and Perl in order to run:
         <http://www.gnu.org/software/autoconf>
         <http://www.gnu.org/software/m4/>
         <http://www.perl.org/>
Makefile:1451: recipe for target 'Makefile.in' failed
make: *** [Makefile.in] Error 1
Kulfy
  • 18,154
