I have recently tried to replace my Ubuntu with windows 7. But it won't work. I first boot my USB drive using woeusb (winusb) but when I restart my device and boot from usb drive GRUB prompt opens. I don't know which command should I use to simply boot from usb drive to install Windows 7. Anyone please tell me the correct and simple commands to do so. Note: when I enter ls in grub menu it shows (hd0,msdos1) , (hd1). I am having my USB drive as Dev/sda1.
So please send command according to above information. Thanks.
I have to agree with the above (by guiverc). You have to tell your PC's BIOS to boot from USB. On powerup, you'll have to figure out which key to hit to enter the BIOS settings mode. The most common ones I've found are DEL, F2 ,or sometimes F12. Gotta press it at the first splash screen you see, and keep tapping till you get the BIOS. If you get the GRUB prompt, power down and try again. Once you're in BIOS, find the setting to boot from USB. Save and exit, reboot. Hope this helps!
