So i have the normal Firefox Quantum65.0 installed on my Ubuntu 18.04.1 LTS. I want to install Firefox developer edition.
I have already tried:
sudo add-apt-repository ppa:ubuntu-mozilla-daily/firefox-aurora
sudo apt-get update
sudo apt-get install firefox
But it simply re-installs the normal firefox. So i tried:
sudo add-apt-repository ppa:ubuntu-desktop/ubuntu-make
sudo apt-get update
sudo apt-get install ubuntu-make
And when i run umake web firefox-dev i get Choose installation path: /home/me/.local/share/umake/web/firefox-dev And when i press Enter i get the following error:
ERROR: One default was already registered, can't register a second one in that choices set: ['en-US', 'en-US', 'ach', 'af', 'sq', 'ar', 'an', 'hy-AM', 'as', 'ast', 'az', 'eu', 'be', 'bn-BD', 'bn-IN', 'bs', 'br', 'bg', 'my', 'ca', 'zh-CN', 'zh-TW', 'hr', 'cs', 'da', 'nl', 'en-GB', 'en-CA', 'en-ZA', 'en-US', 'eo', 'et', 'fi', 'fr', 'fy-NL', 'ff', 'gd', 'gl', 'ka', 'de', 'el', 'gn', 'gu-IN', 'he', 'hi-IN', 'hu', 'is', 'id', 'ia', 'ga-IE', 'it', 'ja', 'kab', 'kn', 'cak', 'kk', 'km', 'ko', 'lv', 'lij', 'lt', 'dsb', 'mk', 'mai', 'ms', 'ml', 'mr', 'ne-NP', 'nb-NO', 'nn-NO', 'oc', 'or', 'fa', 'pl', 'pt-BR', 'pt-PT', 'pa-IN', 'ro', 'rm', 'ru', 'sr', 'si', 'sk', 'sl', 'son', 'es-AR', 'es-CL', 'es-MX', 'es-ES', 'sv-SE', 'ta', 'te', 'th', 'tr', 'uk', 'hsb', 'ur', 'uz', 'vi', 'cy', 'xh']
ERROR: Unhandled exception
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/umake/tools.py", line 158, in wrapper
    function(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/umake/frameworks/web.py", line 116, in get_metadata_and_check_license
    UI.delayed_display(TextWithChoices(_("Choose language: {}".format(default_label)), languages, True))
  File "/usr/lib/python3/dist-packages/umake/interactions/__init__.py", line 59, in __init__
    raise BaseException(message)
BaseException: One default was already registered, can't register a second one in that choices set: ['en-US', 'en-US', 'ach', 'af', 'sq', 'ar', 'an', 'hy-AM', 'as', 'ast', 'az', 'eu', 'be', 'bn-BD', 'bn-IN', 'bs', 'br', 'bg', 'my', 'ca', 'zh-CN', 'zh-TW', 'hr', 'cs', 'da', 'nl', 'en-GB', 'en-CA', 'en-ZA', 'en-US', 'eo', 'et', 'fi', 'fr', 'fy-NL', 'ff', 'gd', 'gl', 'ka', 'de', 'el', 'gn', 'gu-IN', 'he', 'hi-IN', 'hu', 'is', 'id', 'ia', 'ga-IE', 'it', 'ja', 'kab', 'kn', 'cak', 'kk', 'km', 'ko', 'lv', 'lij', 'lt', 'dsb', 'mk', 'mai', 'ms', 'ml', 'mr', 'ne-NP', 'nb-NO', 'nn-NO', 'oc', 'or', 'fa', 'pl', 'pt-BR', 'pt-PT', 'pa-IN', 'ro', 'rm', 'ru', 'sr', 'si', 'sk', 'sl', 'son', 'es-AR', 'es-CL', 'es-MX', 'es-ES', 'sv-SE', 'ta', 'te', 'th', 'tr', 'uk', 'hsb', 'ur', 'uz', 'vi', 'cy', 'xh']
What is the problem here exactly and how do i solve it? Any help is appriciated. Thanks
Ajo
  • 203
Ubuntu's official repository and Ubuntu Desktop's repository contains umake versions 16.11.1ubuntu1 and 18.05~bionic1 respectively. This seems to be a bug under that versions of umake. I installed umake from the repository of Galileo Sartor and all seem to work fine under that umake. This repository contains umake version 18.09+201902042247~ubuntu18.04.1 at the time of installation. That umake installed Firefox Developer Edition version 65.0b5.
  • Uninstall previously installed Ubuntu make and Ubuntu Desktop's repository:
    sudo apt autoremove ubuntu-make
    sudo add-apt-repository --remove ppa:ubuntu-desktop/ubuntu-make
  • To install Ubuntu make from above said repository and then firefox-dev:
    sudo add-apt-repository ppa:lyzardking/ubuntu-make
    sudo apt install ubuntu-make
This repository contains daily build versions of umake and is also mentioned in umake - Ubuntu Wiki, so might be considered as a trusted ppa.
Kulfy
  • 18,154
Simply specify the language along with the umake command
umake web firefox-dev --lang en-US
you are welcome to replace the --lang en-US with the language of your choice.
Solution credits from Ubuntu umake issue tracker git
