I config ubuntu server with these command.
sudo a2enmod rewrite
sudo a2ensite 000-default.conf
I edit 000-default.conf like this.
<Directory /var/www/html>
        Options FollowSymLinks
        AllowOverride all
        Require all granted
</Directory>
sudo service apache2 restart
I use let encrypt to create ssl. If I open myweb.com then it redirect to https://myweb.com . But if I open http://myweb.com it show apache page not redirect to https://myweb.com . It look like .htaccess not run.
This is .htaccess code.
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule .* https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteCond %{HTTP_HOST} !^www\. [NC]
RewriteRule .* https://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
How to fix it?
user58519
  • 111
I found one odd issue regarding Apache's .htaccess.
I setup an .htaccess file in the public html directory for basic authentication. I also setup the requisite apache configuration, as directed by many instructional sites, pages, etc., so I know I had the setup mostly correct.
Regardless of how I had apache configured, I would never get an authentication prompt.
Since I had the password stored in the parent directory to the public html directory, I needed to include that directory in the apache definition.
Here is the original definition:
<Directory /srv/www/mysite/public_html>
  Options Indexes FollowSymLinks MultiViews
  AllowOverride All
  Require all granted
</Directory>`
I then changed the configuration code to the following:
<Directory /srv/www/mysite>
  AllowOverride All
  Require all granted
</Directory>`
The password file is stored in /srv/www/mysite/access/.htpasswd. Per the first configuration pattern, this directory was outside the configuration scope.
By backing up a directory (parent of public html), the "access" directory is now in scope. Now apache presents a login prompt.
Now I found the answer.
RewriteCond %{HTTPS} off not work it have to replace with RewriteCond %{HTTPS} !on
user58519
  • 111
