12
Sadly I decided to upgrade to 18.04. Now I pass half of my work hours fixing bugs.
Today specialty is: suspend the laptop. Last time I tried to suspend my XPS15 9570 I almost burned up my new 2000$ because it was running for 3 hours in my backpack instead of being suspended.
As well documented in a lot of threads, out of the box 18.04 on a lot of laptop is unable to suspend the laptop. There are official bug reports 3 years old, no solution or fix whatsoever. It will simply wake up after 5 seconds or when you close the lid (very sneaky, very dangerous).
https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1574120 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1786094
I tried everything, the only solution that works for me is the one reported here:
Ubuntu 18.04 - Dell XPS13 9370 no longer suspends on lid close
that is changing the grub config to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash mem_sleep_default=deep"
With this change the system actually suspend properly, but when it wakes up wi-fi/bluetooth adapter are completely dead, not even a reboot is able to bring them back.
Something similar is reported here
https://bugzilla.kernel.org/show_bug.cgi?id=201469
and maybe here https://bugzilla.redhat.com/show_bug.cgi?id=1514836
I also tried to hibernate, without any success (the system will simply shut down). This is probably my fault since I'm missing a swap partition.
After passing the whole day reading and trying solution I decide to open this thread. My question is simple: how can I, end user in 2019, suspend my laptop without shutting down wifi or other key components of my HW?
I know that I sound arrogant but I lost one day of work on a standard feature that should not pose any problem.
Thank you for any assistance, I hop you had a better day than mine.
tpd
  • 383
Edit /etc/default/grub with
sudo vim /etc/default/grub
make sure that the GRUB_CMDLINE_LINUX line has the following items:
GRUB_CMDLINE_LINUX="nouveau.blacklist=1 acpi_osi=! acpi_osi=\"Windows 2015\" acpi_backlight=vendor mem_sleep_default=deep"
or
GRUB_CMDLINE_LINUX="nouveau.blacklist=1 mem_sleep_default=deep"
Insert acpi_osi=! acpi_osi=\"Windows 2015\ will not change screen brightness.
update grub:
sudo update-grub
reboot after computer has restarted, try suspending to see if the laptop wakes up normally
zx485
  • 2,865
玉麒麟
  • 101
First answer option 2
did it for me. XPS 15 9570 Ubuntu 18.04
I did not need to edit that /lib/systemd/system-sleep script.
I stumbled across OP's option a few days ago:
but laptop would wake up instantly.
I reactivated this old script in /lib/systemd/system-sleep/custom-xhci_hcd and then it worked:
#!/bin/bash
# Original script was using /bin/sh but shellcheck reporting warnings.
# NAME: custom-xhci_hcd
# PATH: /lib/systemd/system-sleep
# CALL: Called from SystemD automatically
# DESC: Suspend broken for USB3.0 as of Oct 25/2018 various kernels all at once
# DATE: Oct 28 2018.
# NOTE: From comment #61 at: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/522998
TMPLIST=/tmp/xhci-dev-list
# Original script was: case "${1}" in hibernate|suspend)
case $1/$2 in
  pre/*)
    echo "$0: Going to $2..."
    echo -n '' > $TMPLIST
          for i in `ls /sys/bus/pci/drivers/xhci_hcd/ | egrep '[0-9a-z]+\:[0-9a-z]+\:.*$'`; do
              # Unbind xhci_hcd for first device XXXX:XX:XX.X:
               echo -n "$i" | tee /sys/bus/pci/drivers/xhci_hcd/unbind
           echo "$i" >> $TMPLIST
          done
  post/*)
    echo "$0: Waking up from $2..."
    for i in `cat $TMPLIST`; do
              # Bind xhci_hcd for first device XXXX:XX:XX.X:
              echo -n "$i" | tee /sys/bus/pci/drivers/xhci_hcd/bind
    done
    rm $TMPLIST
esac
The screen briefly flashes once while suspending but it's worked 100% since I activated kernel's deep sleep parameter.
