edit: this turned out to have been caused by installing the binary HPLIP printer package. See comments below.
I just ran apt dist-upgrade, but cancelled it before progressing, so it shouldn't have done anything. Unfortunately, I suspect it might have done something after all, as running apt upgrade didn't work after this, as well as any other apt command. They all produce the same output (see below), complaining python3 is not installed, although it is. Trying to install it brings the same errors as the rest (output is partly Norwegian, partly English):
sudo apt install python3
Leser pakkelister ... Ferdig
Skaper oversikt over avhengighetsforhold
Leser tilstandsinformasjon ... Ferdig
Du har allerede nyeste versjon av python3 (3.6.7-1~18.04).
Følgende pakke ble automatisk installert og er ikke lenger påkrevet:
libllvm6.0
Bruk «sudo apt autoremove» for å fjerne den.
0 oppgraderte, 0 nylig installerte, 0 å fjerne og 4 ikke oppgradert.
80 pakker ikke fullt installert eller fjernet.
Etter denne operasjonen vil 0 B ekstra diskplass bli brukt.
Vil du fortsette? [J/n]
Setter opp python3 (3.6.7-1~18.04) ...
running python rtupdate hooks for python3.6...
E: py3compile:183: cannot create directory /usr/share/hplip/ui5/__pycache__: FileNotFoundError(2, 'No such file or directory')
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettings_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of update-notifier-common:
update-notifier-common krever python3:any. Men:
Pakke python3 er ikke satt opp enda.
dpkg: error processing package update-notifier-common (--configure):
kravproblem - setter ikke opp pakken
dpkg: dependency problems prevent configuration of libglib2.0-dev-bin:
libglib2.0-dev-bin krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package libglib2.0-dev-bin (--configure):
dpkg: dependency problems prevent configuration of python3-update-manager:
python3-update-manager krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package python3-update-manager (--configure):
Ingen apport-rapport skrevet fordi feilmeldingen indikerer at den er en følgefeil fra en tidligere feil.
Ingen apport-rapport skrevet for MaxReports allerede er nådd
dpkg: dependency problems prevent configuration of python3-dev:
python3-dev krever python3 (= 3.6.7-1~18.04). Men:
dpkg: error processing package python3-dev (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell krever python3. Men:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of apport-gtk:
apport-gtk krever python3. Men:
dpkg: error processing package apport-gtk (--configure):
dpkg: dependency problems prevent configuration of apturl:
apturl krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package apturl (--configure):
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-core:
ubuntu-release-upgrader-core krever python3:any (>= 3.2~). Men:
dpkg: error processing package ubuntu-release-upgrader-core (--configure):
dpkg: dependency problems prevent configuration of python3-apport:
python3-apport krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package python3-apport (--configure):
dpkg: dependency problems prevent configuration of libglib2.0-dev:amd64:
libglib2.0-dev:amd64 krever libglib2.0-dev-bin (= 2.56.3-0ubuntu0.18.04.1). Men:
Pakke libglib2.0-dev-bin er ikke satt opp enda.
dpkg: error processing package libglib2.0-dev:amd64 (--configure):
dpkg: dependency problems prevent configuration of python3-problem-report:
python3-problem-report krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package python3-problem-report (--configure):
dpkg: dependency problems prevent configuration of ubuntu-drivers-common:
ubuntu-drivers-common krever python3:any (>= 3.3.2-2~). Men:
dpkg: error processing package ubuntu-drivers-common (--configure):
dpkg: dependency problems prevent configuration of python3-uno:
python3-uno krever python3:any (>= 3.3.2-2~). Men:
python3-uno krever python3 (<< 3.7). Men:
python3-uno krever python3 (>= 3.6~). Men:
dpkg: error processing package python3-uno (--configure):
dpkg: dependency problems prevent configuration of software-properties-gtk:
software-properties-gtk krever python3:any (>= 3.3.2-2~). Men:
software-properties-gtk krever python3. Men:
software-properties-gtk krever ubuntu-drivers-common (>= 1:0.2.75). Men:
Pakke ubuntu-drivers-common er ikke satt opp enda.
dpkg: error processing package software-properties-gtk (--configure):
dpkg: dependency problems prevent configuration of apturl-common:
apturl-common krever python3:any (>= 3.3.2-2~). Men:
apturl-common krever python3-update-manager. Men:
Pakke python3-update-manager er ikke satt opp enda.
dpkg: error processing package apturl-common (--configure):
.... <snip>
.... continues forever
.... </snip>
dpkg: too many errors, stopping
Det oppsto feil ved behandling av:
python3
libglib2.0-dev-bin
python3-dev
gnome-shell
apport-gtk
apturl
python3-apport
python3-uno
apturl-common
update-notifier
gnome-software
gedit-common
unattended-upgrades
gedit
apport
update-manager
python3-gdbm:amd64
python3-software-properties
gnome-menus
python3-lib2to3
python3-distutils
networkd-dispatcher
python3-distupgrade
software-properties-common
ufw
ubuntu-release-upgrader-gtk
update-manager-core
ubuntu-software
gconf2
python3-apt
libcairo2-dev:amd64
gnome-software-plugin-snap
gdm3
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
Behandlingen ble stoppet på grunn av for mange feil.
Not sure how to progress from here.
Printer: HP Color LaserJet MFP M277dw
