You are killing the program SeondApp, but you are not killing the terminal it is running in. The two are separate things. For example, this is the process tree of running gedit in a terminal:
$ gedit &
[1] 13064
$ pstree -s 13064
systemd───systemd───gnome-terminal-───bash───gedit───4*[{gedit}]
Ignore the systemd, that's the init process, everything running on your machine is a child of systemd. Then, what you see there is that gnome-terminal has launched bash which then runs gedit. If you now kill gedit, that won't affect its parents. However, if you kill one of the parents, that will also kill the child.
Normally, what you would do is to use $!, a special variable that holds the PID of the last process launched to the background. Unfortunately, that doesn't with gnome-terminal which seems to have some sort of complicated launching procedure:
$ gnome-terminal &
[1] 23861
$ ps aux | grep 23861
terdon 24341 0.0 0.0 8684 2348 pts/11 S+ 10:59 0:00 grep --color 23861
$ pgrep gnome-terminal
23866
As you can see above, gnome-terminal seem to re-launch itself after launching and uses a different PID. No idea why, but another good reason to use a different terminal.
So, since the standard approach won't work, we need a workaround. What you can do is use kill -$PID which will kil all processes in the process group (from man kill):
-n where n is larger than 1. All processes in process group n are
signaled. When an argument of the form '-n' is given, and it is
meant to denote a process group, either a signal must be specified
first, or the argument must be preceded by a '--' option, other‐
wise it will be taken as the signal to send.
Putting all this together, here's a working version of your script:
#!/bin/bash
gnome-terminal --geometry=50x30 --working-directory=/$HOME/TEST --title terminal1 \
-e ' sh -c "./FirstAPP; exec bash"'
while true; do
if ! pgrep SecondAPP; then
gnome-terminal --geometry=50x30 --working-directory=/$HOME/TEST \
--title terminal2 -e 'SecondAPP' &
for ((i=0; i<3600; i+=5)); do
sleep 5
break
fi
done
## Now, get the PID of SecondAPP
pid=$(pgrep SecondAPP)
## Using -$pid will kill all process in the process group of $pid, so
## it will kill SecondAPP and its parent process, the terminal.
kill -- -$pid
fi
sleep 5
done
Note that I also remove the [ ] around ! pgrep since that was wrong syntax.
I don't see why you are launching terminals at all though. Here's the same idea, without terminals:
#!/bin/bash
$HOME/TEST/FirstAPP
while true; do
#$HOME/TEST/SecondAPP &
SecondAPP &
pid=$!
sleep 5
break
fi
done
kill $pid
fi
sleep 5
done
Finally, this feels like a strange way of doing things. You might want to ask a new question, explain what you are trying to do and why and we can see if we can find a simpler approach for whatever it is you need.
