I'm installing Ubuntu 18.04 dual boot beside Windows 10. I got the following error:
the grub-efi-amd64-signed package failed to install into target
And the machine doesn't boot. Note that my computer doesn't support UEFI.
First, use a Windows 10 USB stick to fix your partitions(known as "Fix the MBR" or Startup Repair). Make sure you have an EFI partition working with no problems. There are several tutorials on Google to clean and create a new EFI partition from the W10 USB CMD promtp. Then, boot the Ubuntu USB, and select manual installation:
Create the followings partitions: /, SWAP, /home Click to Install Now, and apply the changes.
Long time ago I had this issue, googling and doing this solved my problem. Hope to get good news.
I've tried to fix partitions (known as "Fix the MBR" or Startup Repair), but it didn't help.
The issue itself was in grub package (grub-efi-amd64-signed_1.66.14+2.02~beta2-36ubuntu3.14+linuxmi.deb
for details check here).
I've a similar problem on Asus laptop. I used a DVD bootable Ubuntu and got this error for several times. The problem is mainly raised from the bios setting. In my case, I went to my bios setting, boot section, delete "UEFI: Ubuntu" from the choices. Then I chose the other Ubuntu (for legacy mode) boot option and placed in the first priority. Finally, I succeeded to install the Ubuntu 18.04.3 along with win 10.
