UPDATE 2
Top posting because it is needed to apply the suggested solution.
Found on second answer to this question: Can netplan configured nameservers supersede (not merge with) the DHCP nameservers:
This has been fixed in the netplan repository on github, and will presumably make its way into Ubuntu at some point.
Two new options have been added, dhcp4-overrides and dhcp6-overrides. To ignore DNS servers from DHCP you would do something like
Anyone knows how to update netplan in Ubuntu 18.04?
Original question
I have an LXD vm with 2 network interfaces. If I use Ubuntu 16.04 (interfaces) I have 1 default gateway. If I use Ubuntu 18.04 (netplan) I have 2 default gateways. How can I get rid of the second gateway?
Ubuntu 16.04 configuration:
root@servizi:/etc/network/interfaces.d# ls -lha
total 3.5K
drwxr-xr-x 2 root root   4 Jul 31  2017 .
drwxr-xr-x 7 root root   8 Jul 12  2017 ..
-rw-r--r-- 1 root root 367 Jul 30  2017 50-cloud-init.cfg
-rw-r--r-- 1 root root  97 Jul 31  2017 60-locale.cfg
root@servizi:/etc/network/interfaces.d# cat 50-cloud-init.cfg
# This file is generated from information provided by
# the datasource.  Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
auto lo
iface lo inet loopback
auto eth0 iface eth0 inet dhcp root@servizi:/etc/network/interfaces.d# cat 60-locale.cfg auto eth1 iface eth1 inet dhcp up route add -net 192.168.99.0 netmask 255.255.255.0 gw 10.0.1.1 root@servizi:/etc/network/interfaces.d# route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 0.0.0.0 10.220.90.1 0.0.0.0 UG 0 0 0 eth0 10.0.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1 10.220.90.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 192.168.99.0 10.0.1.1 255.255.255.0 UG 0 0 0 eth1 root@servizi:/etc/network/interfaces.d#
Ubuntu 18.04 configuration
root@servizi2:/etc/netplan# ls -lh
total 2.0K
-rw-r--r-- 1 root root 381 Jan 24 17:30 50-cloud-init.yaml
-rw-r--r-- 1 root root 177 Feb  1 20:25 60-locale.yaml
root@servizi2:/etc/netplan# cat 50-cloud-init.yaml
network:
    version: 2
    ethernets:
        eth0:
            dhcp4: true
root@servizi2:/etc/netplan# cat 60-locale.yaml
# seconda scheda
network:
    version: 2
    ethernets:
        eth1:
            dhcp4: true
            routes:
            - to: 192.168.99.0/24
            via: 10.0.1.1
root@servizi2:/etc/netplan# route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 0.0.0.0 10.220.90.1 0.0.0.0 UG 100 0 0 eth0 0.0.0.0 10.0.1.1 0.0.0.0 UG 100 0 0 eth1 10.0.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1 10.0.1.1 0.0.0.0 255.255.255.255 UH 100 0 0 eth1 10.220.90.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 10.220.90.1 0.0.0.0 255.255.255.255 UH 100 0 0 eth0 root@servizi2:/etc/netplan#
UPDATE
Tried what @slangasek suggested and the second file is now:
# seconda scheda
network:
    version: 2
    ethernets:
        eth1:
            dhcp4: true
            dhcp4-overrides:
                    use-routes: false
            routes:
                  via: 10.0.1.1
But netplan try gives the error "unknown key dhcp4-overrides"
root@servizi2:/etc/netplan# netplan try
Error in network definition /etc/netplan/60-locale.yaml line 5 column 12: unknown key dhcp4-overrides
An error occurred: the configuration could not be generated
Reverting. root@servizi2:/etc/netplan#
Wha can I do?
It appears you have a default route on both eth0 and eth1 that is coming from dhcp; and you want to use only the default route through eth0.
To ignore the default route provided by your dhcp server, you would need to use dhcp4-overrides, like so:
network:
    version: 2
    ethernets:
        eth1:
            dhcp4: true
            dhcp4-overrides:
                use-routes: false
            routes:
                  via: 10.0.1.1
This option is only supported in netplan 0.95 and later, which is currently available in Ubuntu 18.04 LTS and later releases.
slangasek
  • 5,828
cat /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg
and
cat /etc/netplan/50-cloud-init.yaml
network:
    ethernets:
        ens3:
            dhcp4: true
            dhcp4-overrides:
                use-routes: false
            gateway4: 10.2.100.101
            match:
                macaddress: 52:54:00:0e:ad:cc
            set-name: ens3
    version: 2
In case you have to define second default gateway for the second NIC you can use this example:
# networks
network_1 ens3: 10.0.10.0/24
network_2 ens8: 10.0.20.0/24
network: version: 2 renderer: networkd ethernets: ens3: dhcp4: yes ens8: dhcp4: yes dhcp4-overrides: use-routes: false routes: - to: default via: 10.0.20.1 table: 200 - to: 10.0.20.0/24 via: 10.0.20.1 table: 200 routing-policy: - from: 10.0.20.0/24 table: 200
see also: https://netplan.readthedocs.io/en/latest/examples/#how-to-configure-source-routing
panticz
  • 1,936
