There is a way to redirect what you install to the HDD afterwards by using custom folders for folders in /home in order to span your home directory across multiple hard disks. In your case the multiple hard disks are the 128GB SSD and the 1TB HDD.
Example (xdg-user-dirs-update - Update XDG user dir configuration):
xdg-user-dirs-update --set DOWNLOAD /media/askubuntu/1TB-HDD/Downloads/
would switch from /home/$USER/Downloads/ to /media/askubuntu/1TB-HDD/Downloads/ and downloaded files would then download to the HDD and not to the SSD. The same applies for all the other directories.
Both the local ~/.config/user-dirs.dirs and global
/etc/xdg/user-dirs.defaults configuration files use the following
environmental variable format to point to user directories:
XDG_DIRNAME_DIR="$HOME/directory_name" An example configuration file
looks like this (these are all the template directories):
Results of cat ~/.config/user-dirs.dirs :
XDG_DESKTOP_DIR="$HOME/Desktop"
XDG_DOCUMENTS_DIR="$HOME/Documents"
XDG_DOWNLOAD_DIR="$HOME/Downloads"
XDG_MUSIC_DIR="$HOME/Music"
XDG_PICTURES_DIR="$HOME/Pictures"
XDG_PUBLICSHARE_DIR="$HOME/Public"
XDG_TEMPLATES_DIR="$HOME/Templates"
XDG_VIDEOS_DIR="$HOME/Videos"
As xdg-user-dirs will source the local configuration file to point
to the appropriate user directories, it is therefore possible to
specify custom folders. For example, if a custom folder for the
XDG_DOWNLOAD_DIR variable has been named $HOME/Internet in
~/.config/user-dirs.dirs any application that uses this variable
will use this directory.
