I tried to install npm in my ubuntu 18.04 using apt-get, my thrown some errors called,
npm: depends: node-gyp (>= 0.10.9) but it is not going to be installed.
I found one solution that says install aptitude first the install npm using
sudo aptitude install npm
And then the npm installed successfully, but i cannot do any apt operations.
Please help me to fix this.
Thanks in advance.
Satya
  • 191
As you are working on the Ubuntu 18.04, By default It will have the apt-get Installed. if this Command is not found means the Installation of Ubuntu is not Proper. Please have a check with it.
Follow this Link.
-1
As the @Sunil Valmiki said, Aptitude is also a package manager and has pros and cons. You can continue to use aptitude if that is ok for you. As your apt-get problem, there is no way i can think of to repair apt-get. Apt-get is a part of the installation, the operating system. When you tried to solve your npm problem you may have caused some conflict between aptitude and apt-get that you haven't notice. You may need to install ubuntu again.
Ugur Akgul
  • 64
