So I am trying to install virtualbox 6.0 on Ubuntu 18.04.1 LTS and it seems to be having dependency problems.
I've confirmed the sources.list file contains
deb http://download.virtualbox.org/virtualbox/debian bionic contrib
and I have used update multiple times with nothing showing up to be updated.
Also apt-get -f install did not help either. Here is what I get when i run sudo apt-get install virtualbox-6.0:
 virtualbox-6.0 : Depends: libqt5x11extra5 (>= 5.6.0) but it is not installable
                  Recommends: libsdl-ttf2.0-0 but it is not installable
                  Recommends: pdf-viewer
And dpkg --get-selections | grep hold doesn't return anything.
Any ideas?
Olorin
  • 3,548
sean
  • 51
got mine working by changing sources.list line
deb https://download.virtualbox.org/virtualbox/debian xenial contrib
to
deb [arch=amd64] https://download.virtualbox.org/virtualbox/debian bionic contrib
piouson
  • 139
I'm running Ubuntu and ran into this dependency problem. Only difference is I'm using xenial distrubution. So here's what fixed it. From this forum.
User scottgus1 stated the following "I'm going to guess that unless you have specifically pointed your repository for Virtualbox to official www.virtualbox.org Virtualbox via the command on https://www.virtualbox.org/wiki/Linux_Downloads, then you're pulling a fork of Virtualbox, and an old fork at that. Forks may be modified from the official version and we don't know what modifications were made. We recommend official Virtualbox for Linux."
So I literally changed the command:
sudo apt-get install virtualbox-6.1
to:
Worked instantly for me.
