Having an issue updating Ubuntu 18.04 install
sudo apt update
works fine, then
sudo apt upgrade
fails with
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies.
libgdk-pixbuf2.0-0 : Depends: libglib2.0-0 (= 6= 2.48.0) but 2.56.3-0ubuntu0.18.04.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
then running:
sudo apt --fix-broken install
gives
The following additional packages will be installed:
libgdk-pixbuf2.0-0
The following packages will be upgraded:
libgdk-pixbuf2.0-0
followed by:
dpkg: warning: parsing file '/var/lib/dpkg/status' near line 14881 package 'libgdk-pixbuf2.0-0:amd64':
'Depends' field, reference to 'libglib2.0-0':
implicit exact match on version number, suggest using '=' instead
dpkg: error: parsing file '/var/lib/dpkg/status' near line 14881 package 'libgdk-pixbuf2.0-0:amd64':
'Depends' field, reference to 'libglib2.0-0': version contains ' '
E: Sub-process /usr/bin/dpkg returned an error code (2)
edit:
$ apt-cache policy libgdk-pixbuf2.0-0:amd64 libglib2.0-0
libgdk-pixbuf2.0-0:
Installed: 2.36.11-2
Candidate: 2.36.11-2
Version table:
2.36.11-2 500
500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
*** 2.36.11-2 100
100 /var/lib/dpkg/status
libglib2.0-0:
Installed: 2.56.3-0ubuntu0.18.04.1
Candidate: 2.56.3-0ubuntu0.18.04.1
Version table:
*** 2.56.3-0ubuntu0.18.04.1 100
2.56.1-2ubuntu1 500
edit2: after re-enabling the package sources
$ sudo apt update
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:2 http://gb.archive.ubuntu.com/ubuntu bionic InRelease
Get:3 http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Fetched 177 kB in 0s (384 kB/s)
Reading package lists... Done
Building dependency tree
122 packages can be upgraded. Run 'apt list --upgradable' to see them.
then
$ sudo apt full-upgrade
libgdk-pixbuf2.0-0:
Version table:
2.36.11-2 500
500 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
*** 2.36.11-2 100
libglib2.0-0:
Version table:
*** 2.56.3-0ubuntu0.18.04.1 500
500 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
2.56.2-0ubuntu0.18.04.2 500
500 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
2.56.1-2ubuntu1 500
