I lost my unity 3d, and I want to install it back. But when I want to install it back, it raises this error:
utm@utm:~$ sudo apt-get install unity
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: unity : Depends: compiz-core-abiversion-20110828 E: Unable to correct problems, you have held broken packages.
Is there any way around to fix this?
karel
  • 122,292
  • 133
  • 301
  • 332
Use aptitude to resolve problems, it's better then apt-get.
sudo apt-get install aptitude
sudo apt-get update && sudo aptitude -f install && sudo aptitude dist-upgrade
sudo aptitude install unity
also run this (which'll save you some time in the future). When holding [Alt] and typing ai inserts sudo aptitude install under cursor :-)
echo  "\"\\ea\\ei\": \"sudo aptitude install \"" >> ~/.inputrc
Jorge Castro
  • 73,717
This is quite normal for a development version.
sudo apt-get update
sudo apt-get dist-upgrade
Afterwards you should be able to install unity.
