I've Googled a bit and not really found anything out. I want to install Crashplan for remote upload on Crashplan+. How painless is the installation and set up?
Crashplans site is lacking a lot of information from what I've looked at.
The server is headless and while it has GNOME installed, it's not used. So I need something completely console driven.
Jorge Castro
  • 73,717
Sam
  • 133
As long as your usage on that server will be Set & Forget. You will find it very difficult to tweak CrashPlan settings without occasional GUI interaction. I have VNC access to mine for the occasional session - I find I am in there once or twice a month either checking on things or changing something.
You'll find that all the more important if your server is going to be the local backup destination as well as a client for the cloud service. If it's only the latter, you may indeed be Set & Forget in which case Meddy's answer is ALL you need.
DavidF
  • 178
This should work http://nerdwa.com/index.php/2011/05/crashplan-on-ubuntu-server/
There's some stuff at the end about editing the client on a mac but the first 2 commands are for Ubuntu installation and likely all you need
Meddy
  • 650
