The target shouldn't have any wildcards. Best to learn to use the trailing /, or not, as needed.
-p in rsync is permissions, not port. From the manpage:
-p, --perms preserve permissions
rsync has used ssh for remote connections by default for at least a decade. No need to specify -e anything. The port can be added to the URL - userid@remote-server:port/path/to/target/ . If the userid is the same as the source machine, it isn't needed.
Since ssh is used by default, using the ~/.ssh/config file to handle non-standard settings like alternate ports, different userids, or different keys makes rsync commands simpler. It is handy for using a name when either the DNS name is ugly or only IPs are possible too. I find the config file is a good way to document, in a useful, all the foreign systems where I have accounts, logins, and use non-standard ports.
There are two different ways for rsync to contact a remote system:
using a remote-shell program as the transport (such as ssh or rsh) or
contacting an rsync daemon directly via TCP. The remote-shell transâ
port is used whenever the source or destination path contains a single
colon (:) separator after a host specification.
But this is more about ssh-fu, than rsync-fu.
The rsync manpage is extremely comprehensive. Many people find that explainshell.com is helpful for complex commands like rsync or find. If you plug the original command into explainshell, the -p jumps out as an issue.
So, after the above simplifications (especially using the ~/.ssh/config file, the commands becomes:
$ rsync -avru --exclude-from='/home/me/exclude-me.txt' ~/* assistant@assistant.local:2222/home/assistant/
I would put the userid, unfriendly hostname, port into the config and do it this way:
$ rsync -avz --exclude-from='/home/me/exclude-me.txt' ~/ backsrv:
The ~/* or /home/me/* will miss anything that begins with a period, like config files and the ~/.config/ directory. If you want those, and you should, then a specific regex is needed OR just use /home/me as the source without any regex pattern. See above.
Note how I didn't specify any directory on the target? By default, the userid's HOME is used.
And don't forget about the --dry-run option:
-n, --dry-run perform a trial run with no
changes made
If the goal is for a daily backup, perhaps using a tool with versioned backups would make sense?
