I am running 18.04 and trying to use version 2.1 of the R package pdftools. Some functionality requires poppler >= 0.73. (A poppler version requirement is documented in ?pdftools::pdf_data.)
I obtained poppler-0.73.0.tar.xz and poppler-data-0.4.9.tar.gz from https://poppler.freedesktop.org/. I extracted, followed the INSTALL instructions, and all seemed to work. I can verify that /usr/lib/x86_64-linux-gnu/libpoppler.so points to /usr/lib/x86_64-linux-gnu/libpoppler.so.73. I'm not sure what else to look for or whether update-alternatives would be helpful.
In R, when I run pdftools::pdf_data this happens:
> pdf_data(fn)
Error in poppler_pdf_data(loadfile(pdf), opw, upw) :
  pdf_data() requires poppler >= 0.73. You have 0.62.0
Other functions in pdftools work, but pdf_data is documented to required poppler >= 0.73. I'm wondering what else I need to do to have 0.73 recognized.
EDIT: Following helpful suggestions at Installing poppler-0.62.0 on ubuntu 16.04, I ran apt-cache policy poppler-0.73 and got:
poppler-0.73:
  Installed: 20190125-0.73
  Candidate: 20190125-0.73
  Version table:
 *** 20190125-0.73 100
        100 /var/lib/dpkg/status
This seems to suggest that 0.73 is installed.
The output of apt-cache policy r-base-core is
r-base-core:
  Installed: 3.5.2-1bionic
  Candidate: 3.5.2-1bionic
  Version table:
 *** 3.5.2-1bionic 500
        500 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ Packages
     3.5.1-2bionic 500
     3.5.1-1bionic 500
     3.5.0-1bionic 500
     3.4.4-1ubuntu1 500
        500 http://ubuntu.osuosl.org/ubuntu bionic/universe amd64 Packages
I created a PPA with backports of Poppler 0.74.0 for Ubuntu 16.04 (Xenial) and Ubuntu 18.04 (Bionic). This is now the recommended way to update your poppler.
sudo add-apt-repository -y ppa:cran/poppler
sudo apt-get update
sudo apt-get install -y libpoppler-cpp-dev
To make it working we need to do the following:
  1. Uninstall the libpoppler-cpp-dev package
    sudo apt purge libpoppler-cpp-dev
  2. Compile and install Poppler 0.73 with checkinstall (as you already did) to the /usr/local:
    sudo apt-get install libopenjp2-7-dev libgdk-pixbuf2.0-dev cmake checkinstall
    sudo apt-get build-dep libpoppler-cpp-dev
    cd ~/Downloads
    wget https://poppler.freedesktop.org/poppler-0.73.0.tar.xz
    tar -xf poppler-0.73.0.tar.xz
    cd poppler-0.73.0
    mkdir build
    cd build
    cmake ..
    sudo checkinstall make install
  3. Define the environment variable R_LD_LIBRARY_PATH to inform R about the Poppler libraries in /usr/local/lib:
    echo "export R_LD_LIBRARY_PATH=\$R_LD_LIBRARY_PATH:/usr/local/lib" >> .bashrc
  4. Compile the pdftools R-package inside R-shell:
    install.packages("pdftools")
  5. Test it from R-shell with any pdf-file
    > pdftools::pdf_data(pdf="/usr/share/cups/data/default.pdf")
    [1]]
    [1] width  height x      y      space  text
    <0 rows> (or 0-length row.names)
Note: I tested this method on my clean Ubuntu 18.04 LTS VM with both R 3.4 and 3.5.2 from R-shell and from RStudio.
N0rbert
  • 103,263
