I have two FullHD monitors attached to my ATI graphics card [2]. The resolution of both of them is detected properly without any modifications to /etc/X11/xorg.conf. I can run both of them in clone mode. However, when I try to run them next to each other, I got the following error: The selected configuration for displays could not be applied. If tried to fix this according to [1]. My xorg.conf now looks like this:
Section "Module"
        Load    "glx"
EndSection
Section "Screen"
        Identifier      "Default Screen"
        DefaultDepth    24
        SubSection "Display"
              # The 1088 is the smallest multiple of 32 >= 1088
              # see manpages
              Virtual 1920 1088
        EndSubSection
EndSection
This does not seem to be parsed properly. After restarting X, I cannot set resolutions beyond 1600 or so any more. /var/log/Xorg.0.log gives:
[    15.676] (II) fglrx(0): Not using mode "1920x1080" (width too large for virtual size)
[    15.676] (II) fglrx(0): Not using mode "1680x1050" (width too large for virtual size)
Are my modifications syntactically incorrect? According to the man page, it should be fine. Any ideas?
OS: Ubuntu 11.10 64bit
[1] https://askubuntu.com/a/75546/5023
[2] 01:00.0 VGA compatible controller: ATI Technologies Inc Juniper [Radeon HD 5700 Series]
Stefan
  • 153
if you want both screens next to each other your virtual size must be at least
Virtual 3840 1080
EDIT:
It seems like you need to extend the height too, so using
Section "Screen"
        DefaultDepth    24
              Virtual 3840 3840
        EndSubSection
EndSection
as xorg.conf works for me
ThomasKl
Have you checked the output of /var/log/Xorg.0.log ? Your Screen section looks correct, what does your Monitor section look like?
Section "Monitor"
    Identifier  "Monitor1"
    HorizSync   28-110
    VertRefresh 43-90
    Modeline "1920x1200" 162 1920 1984 2176 2480 1200 1201 1204 1250 +hsync +vsync
EndSection
Section "Monitor" Identifier "Monitor2" HorizSync 28-110 VertRefresh 43-90 Modeline "1920x1200" 162 1920 1984 2176 2480 1200 1201 1204 1250 +hsync +vsync EndSection
If checking your Monitor sections doesn't fix your issue, my next step would be to remove some of your GUI based settings files.
~/.dt
~/.dtprofile
Linztm
  • 683
