I am running a Thinkpad T480 with Ubuntu 16.04 and i want to disable the audio mute led. (This led is on when the sound is muted, which is pretty much all the time).
So far i have followed instruction c-2 of the first answer of the following question: Enabling Mic Mute button and light on Lenovo Thinkpads This allowed me to disable the mic mute light. However it does not allow me to disable the audio mute led.
I have also patched thinkpad_acpi to allow all leds to be changed and added a soundmute value to the tpacpi_led_names. This adds a directory in /sys/clas/leds but setting 0 in the brightness file does not turn off the led.
I used this thinkpad_acpi version for ubuntu-bionic (16.04): https://kernel.ubuntu.com/git/gavinguo/ubuntu-bionic.git/tree/drivers/platform/x86/thinkpad_acpi.c?h=hf203191v20181105b1habae6bf60e7c
Dibido
  • 31
I am using a ThinkPad T480 running Linux Mint 21.1 - Cinnamon 5.6.8 - kernel 5.15.0-69-generic.
I just encountered the Audio Mute (F1) Key LED issue with the LED stuck in the On position. Pressing the key displays the Audio Status pop-up and shows mute being turned off and back on (with a second press), however the LED light and Mute do not turn off.
I was able to get the LED and Mute to turn off by launching Terminal and using the pulseaudio command. The first command pulseaudio -k will kill the PulseAudio process and the second command pulseaudio --start will start the PulseAudio process.
pulseaudio -k
pulseaudio --start
The LED turned off and is functioning normally with PulseAudio stopped and started.
Some context:
I am using AirPods connected via Bluetooth and playing audio using the Audacious app. The AirPods are the only variable that I have introduced recently. I have had a few system and app updates, and I have not yet verified a version change for Audacious or PulseAudio.
karel
  • 122,292
  • 133
  • 301
  • 332
Aeson
