I have two files A and B. I need the contents of A to be accessible only by root, so I have run the command chmod 000 A.
Now, I want file B to be able to access file A without asking for the root password. How can I go about this?
Let's assume we have two files A and B. The both files are located in the home directory of a regular user. The file A is owned by root and only that user has read permissions as follow:
$ cat A # output the content of the file
"Test content of file A"
$ chmod 400 A # change the permissions of file A to read only by the user/owner
$ sudo chown root:root A # change the ownership of the file to user and :group 'root'
$ ls -l A # check the permissions and the ownership, 'stat -c "%a %n" A' to get them in octal
-r-------- 1 root root 24 яну 22 10:17 A
$ sudo cat A # output the content of the file A, that is ownes by 'root'
The file B is simple script that outputs the content of A, it is owned by the regular user. B has executable permissions as follow:
$ cat B # output the content of the file
#!/bin/bash
cat /home/<user>/A
$ chmod +x B # add executable permissions to the file for all users
$ ./B # execute file B by a regular user
cat: /home/<user>/A: Permission denied
$ sudo ./B # execute file B with root privileges
[sudo] password for <user>:
To execute the last command above without password we can use NOPASSWD directive within the file /etc/sudoers or we can create separate file, dedicated to this task, located in /etc/sudoers.d/ (as it is in the next example). Note, the use of the command visudo is absolutely necessary when you edit files as these. So, run the command:
$ sudo visudo -f /etc/sudoers.d/no-passwd-A-B
Add the following content inside, save and close:
<user> ALL=(ALL) NOPASSWD: /bin/cat /home/<user>/A
Now you will be able to execute the following command and you will not be asked for a password:
$ sudo ./B
If you do not want to type sudo in front of the command, you can put it inside the script:
#!/bin/bash
sudo cat /home/<user>/A
$ ./B
NOTE: In the previous version of the answer is described how to add
NOPASSWDdirective insudoersfile for a script (fileBin our case), but, as @RoVo said, this approach is pretty dangerous, because if the user has write permissions to the file it can make harmful changes inside. Practically the user will be able to do/crash anything.If you want to use this variant, where the content of
/etc/sudoers.d/no-passwd-A-Bis:<user> ALL=(ALL) NOPASSWD: /home/<user>/BThen for security reasons, change the ownership of the file
Bto root and grant it only read and execute (but not write) permissions for the other users, something like:$ chmod 605 B $ sudo chown root:root B $ ls -l B -rw----r-x 1 root root 38 яну 22 15:31 BAnother way to add more security in your system, provided by @PerlDuck, is to have
sudocheck the executable against manipulation:
For this purpose get the sha256sum of the executable file:
$ openssl dgst -binary -sha256 /home/<user>/B | openssl base64 sfDELCTNqfrDY9QKzz8Ra2wTnIpFXyyN8sG9JFxUJtA=Add that sha256sum to the sudoers file like so:
<user> ALL=(ALL) NOPASSWD: sha256:sfDEL...xUJtA= /home/<user>/BThen
sudowill complain if the sha256 of the script doesn't match the value in the sudoers file.
