Having looked at all of the questions regarding the setup of the HP LaserJet P1102w on Ubuntu (various versions) on this site (as well as many others), I'm still having no success at all. I've tried hplip & CUPS. If you need log files or any other information, please let me know. It's critical that I be able to print on this printer; I have an inkjet, but many of my documents that need printed are in the 100- to 200-page range, so, needless to say, that'd use a ton of inkjet ink (and the job probably wouldn't finish printing). Thanks in advance!
Steps I took to install HPLIP on 1/24/2019:
In Chromium, browsed to https://developers.hp.com/hp-linux-imaging-and-printing
Clicked on See "All Supported Printers" (opened in a new Chromium tab) and searched for "P1102w"
found that it was listed as being supported in 3.10.4 & 3.12.6
Went back to the tab for https://developers.hp.com/hp-linux-imaging-and-printing
Clicked on "Download HPLIP"
Selected "Ubuntu" as the Distro
Clicked "Download HPLIP", which opened into a new tab (sourceforge), followed by a window to save the file (I chose the "Downloads" folder) - hplip-3.18.12.run was the filename
After the download completed, I clicked on "...'click here' for installation instructions."
Seeing "These instructions assume that the hplip-3.18.12.run file was downloaded to your Desktop directory...", I moved the file from "Downloads" into "Desktop" in Files.
I then followed the instructions that the webpage enumerated, as follows:
Opened a Terminal window Input "cd Desktop" Input "sh hplip-3.18.12.run" Input "a" to use automatic install mode Input "y" to make sure the identified [Linux] Distro was correct (Ubuntu 18.04) Entered the sudoer's password Using Software & Updates, verified the following: that the universe/multiverse repositories were enabled that the main repository was enabled that the CD-ROM/DVD source was disabled since no Ubuntu installation media was inserted in the drive Pressed "Enter" to read the installation notes Answered "yes" to have the installer install the hplip specific policy/profile Answered "yes" to install missing dependencies Saw a message that 2 package managers were running; as I didn't know how to shut them down safely, I input "f" to force said package managers to close Saw a message that HPLIP-3.18.12 exists and that it may conflict with the new one being installed, so I input "i" to Remove and Install Was presented with the option to check for HPLIP Updates; input "y" to do so Was presented with the option to check for HPLIP Plugin Update Notifications; input "y" to do so Was presented with the option to install plug-ins in GUI mode; input "u" to do so
ERROR MESSAGE: Qt: Session management error: Could not open network socket
followed quickly by a new window - "HP Device Manager - Plug-in Installer"
Selected the already-selected option - Download and install the plug-in from an HP authorized server (recommended)
Clicked Next >
After the network connection was verified, I saw this in the Terminal:
Downloading plug-in from: Receiving digital keys: /usr/bin/gpg --homedir /home/mark/.hplip/.gnupg --no permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
followed by a pop-up window saying:
Unable to receive key from keyserver
Without this, it is not possible to authenticate and validate the plug-in prior to installation.
Do you still want to install the plug-in?
                                            No           Yes
Clicked on Yes
Noticed another error message in the Terminal (a repeat of an earlier error message):
Noticed a new pop-up window with the Driver Plug-in License Agreement
Scrolled to the bottom of the lawyer-mandated text (I'm assuming the lawyers mandated it)
Clicked the box to indicate acceptance
Clicked Next >
Another pop-up window - HP Device Manager - Enter Username/Password
Username was filled in
Entered my password
Clicked on OK
In the Terminal, I saw this:
Plugin installation failed error: Python gobject/dbus may be not installed error: Plug-in install failed.
Simultaneously, a pop-up window appeared - HP Device Manager - Plug-in Install with the message Plug-in install failed. Clicked on OK.
Back in the Terminal -
RESTART OR RE-PLUG IS REQUIRED appeared with explanatory text. Since my HP LaserJet P1102w is wireless, input "i" to ignore/continue, as directed by said explanatory text
Still in the Terminal -
PRINTER SETUP appeared with an instruction to make sure the printer is connected and powered on (I pressed the Power button on the front left of the P1102w)
Was asked if I wanted to setup the printer in GUI mode
Input "u" to setup the printer in GUI mode
Another pop-up window - HP Device Manager - Setup - Device Discovery
Selected Wireless/802.11 (requires a temporary USB connection and is only available for select devices)
Clicked Next >
Another pop-up window - HP Device Manager - Wifi Configuration
Per the instructions, I connected a USB cable - first into the rear of the printer, followed by into a USB port on the PC
Clicked Next >
In the window (Step 2 of 5), the printer was successfully identified, so clicked Next >
Step 3 of 5 (Find and Select a Wireless Network) - selected the Wifi network SSID I wanted to connect to and clicked Next >
Step 4 of 5 (Configure Wireless) - selected the appropriate Wireless Security Type and input the Wireless Security Key, then clicked Connect
Another pop-up window which said "Waiting for printer to connect to the wireless network..."
Noticed a message in the Terminal - "warning: Request Failed with Response Code 204" and was then followed by "warning: Request failed with Response code 404. HostName not found."
Step 5 of 5 (Wireless Configuration Results) - said the printer was successfully configured on the wireless network and was instructed to run (in the Terminal) "hp-setup [xxx.xxx.x.xx]"
Clicked Finish
"warning: Request failed with Response code 404. HostName not found." was still showing in the Terminal.
I opened a new Terminal window and ran the command "hp-setup [xxx.xxx.x.xx]"
In the Terminal, I saw this error message again: Qt: Session management error: Could not open network socket
however
the device was found, per the Terminal display
Another pop-up window - HP Device Manager - Setup - Select From Discovered Devices - Step 2 of 3 - appeared with the P1102w identified, so I clicked Next >
The device you are trying to setup requires a binary plug- in. Some functionalities may not work as expected without plug-ins.
Please run 'hp-plugin' as normal user to install plug-ins.
Visit http://hplipopensource.com for more information.
Clicked on OK
Since the indented error message above was also present in the Terminal and a command prompt was not present, I opened a new Terminal window and ran the command "hp-plugin"
Another pop-up window - HP Device Manager - Plug-in Installer - Driver Plug-in Installation - Step 1 of 2
"Download and install the plug-in from an HP authorized server (recommended)" was selected, so I clicked Next >
In the Terminal, this appeared:
Downloading plug-in from: Receiving digital keys: /usr/bin/gpg --homedir /home/mark/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
followed by
I clicked Yes
It went back to the Driver Installation which I had tried earlier before; I clicked Cancel
I saw this in the Terminal afterwards:
Qt: Session management error: Could not open network socket error: License agreement not accepted. Exiting. error: Python gobject/dbus may be not installed error: Plug-in install failed.`
I had a simmilar issue (on a fresh install of Xubuntu 18.04), what worked for me was:
  • Before connecting the printer:
  • sudo apt-get update
  • sudo apt-get install hplip
  • Connected the printer:
  • hp-setup -i
The installation ran with a few basic questions and printed successfully, I hope that this helps someone (on a HP LaserJet P1102w, connected by USB)
Guest
  • 31
