I'm asking this question because I tried a lot of solutions I found and they all didn't work:
  • gnome-terminal --save-config=... results in an error that this option is no more possible
  • gnome-terminal --tab -- 'vim ~/Files/file.txt' for creating a shell script results in an error, my system is in German but it seems to be like
    There was an error creating the child process for this terminal
    Failed to execute child process "vim ~/Files/file.txt" (No such file or directory)
    and does nothing but using just vim without a file to open works
  • using a session manager just opens the Terminal automatically but without any tabs
  • and gnome-terminal --tab -- 'cd ~/Files/' doesn't work either (error like the one above)
The version is # GNOME Terminal 3.28.2 using VTE 0.52.2 +GNUTLS -PCRE2. Maybe there are mistakes in my ways of solving it or you know another (a better) alternative?
Thank you for helping me!
Zanna
  • 72,312
The closest I can find that would do this involves creating multiple scripts. gnome-terminal has changed over the years and the -x and --command options have been heavily deprecated. Your best bet is to create profiles for each of the tabs you want to run and use:
gnome-terminal --tab-with-profile=Something1 --tab-with-profile=Something2
If you're using stuff like ~ or * inside your commands it's likely those won't be evaluated since that's actually the job of the shell (bash) whereas gnome-terminal, so it might help to create an actual script somewhere and tell gnome-terminal to use that.
The script open new tabs:
  1. saves in pathtabs.list a list of (foo-test) paths to new terminal tabs;
  2. creates a new script autotab.sh to xdotool-FORMAT any list of paths adding controlshiftt shortcuts and cds to commands;
  3. autotab.sh is useful to xdotool format <any-list-of-paths>;
  4. usage: autotab.sh <any-list-of-paths>;
  5. creates foo_* test dirs for the pathtabs.list;
  6. runs ./autotab.sh pathtabs.list and saves output to new script maketabs.sh
  7. maketabs.sh is useful to open the same set of tabs/paths from the original pathtabs.list;
...and runs commands:
  1. saves in pathncommtabs.list a list of (foo-test) paths and commands to run in new terminal tabs;
  2. creates a new script autopctab.sh to xdotool-FORMAT any list of paths and commands adding controlshiftt shortcuts, ; and cds to commands;
  3. autopctab.sh is useful to xdotool format <list-of-paths-and-commands> (see pathncommtabs.list);
  4. usage: autopctab.sh <list-of-paths-and-commands>; (see pathncommtabs.list)
  5. runs ./autopctab.sh pathncommtabs.list and saves the command list to new script makepctabs.sh
  6. makepctabs.sh is useful to open the same set of tabs/paths/commands from the original pathncommtabs.list;
#open-several-tabs-with-xdotool-slowly-and-easily
#!/bin/bash
#pathtabs.list
if [ ! -f ~/pathtabs.list ]; then
echo ~/foo_00 > pathtabs.list
echo ~/foo_00/foo_00_1 >> pathtabs.list
echo ~/foo_00/foo_00_2 >> pathtabs.list
echo ~/foo_00/foo_00_2/foo_00_2_1 >> pathtabs.list
fi
echo 'pathtabs.list: has a list of paths for the new tabs'
#mkdirs if [ ! -d ~/foo_00/ ]; then mkdir foo_00 mkdir foo_00/foo_00_1 mkdir foo_00/foo_00_2 mkdir foo_00/foo_00_2/foo_00_2_1 fi echo 'mkdirs: testing foo_*'
##commtabs.list if [ ! -f ~/commtabs.list ]; then echo nano newfile1.txt > commtabs.list echo nano newfile2.txt >> commtabs.list echo nano newfile3.txt >> commtabs.list echo nano newfile4.txt >> commtabs.list fi echo 'commtabs.list: has a list of commands to run on the new tabs'
#pathtabs.list+commtabs.list+options if [ ! -f ~/pathncommtabs.list ]; then cat pathtabs.list |sed 's/.*/cd &;/'|sed '1s/^/c+s+t;/'|
paste - commtabs.list|tr -d '\t' |sed '$!s/$/;c+s+t/' > pathncommtabs.list fi echo 'pathncommtabs.list: integrates pathtabs.list+commtabs.list+cd+;+(new-tab-tokens)'
#autopctab.sh <anypathncommtabs.list> if [ ! -f ~/autopctab.sh ]; then echo '#!/bin/bash' > autopctab.sh echo 'cat $1| sed '''s/ /#/g'''| sed '''s/(.)/\1 /g'''|sed '''s/#/space/g'''|
sed '''s/~/asciitilde/g'''|sed '''s/_/underscore/g'''|sed '''s/c + s + t/control+shift+t/g'''|
sed '''s///slash/g'''|sed '''s/./period/g'''|sed '''s/;/Return/g'''|
sed '''s/.*/xdotool key --delay 18 & Return/'''' >> autopctab.sh chmod u+x autopctab.sh fi echo 'autopctab.sh: xdotool-format paths+commands+(xdotool-commands)'
#run autopctab.sh <pathncommtabs.list> #makepctabs.sh if [ ! -f ~/makepctabs.sh ]; then echo '#!/bin/bash' > makepctabs.sh ./autopctab.sh pathncommtabs.list >> makepctabs.sh chmod u+x makepctabs.sh fi echo 'makepctabs.sh: run xdotool command lines to OPEN new tabs AND RUN commands with pathncommtabs.list'
#autotab.sh <anytabs.list> if [ ! -f ~/autotab.sh ]; then echo '#!/bin/bash' > autotab.sh echo 'cat $1|sed '''s/./cd &/'''|sed '''s/ /#/g'''|
sed '''s/.
/xdotool key --delay 18 control+shift+t space c d space asciitilde Return & Return c l e a r Return/'''' >> autotab.sh chmod u+x autotab.sh fi echo 'autotab.sh: xdotool-format ONLY paths+(xdotool-commands)'
#run autotab.sh <pathtabs.list> #maketabs.sh if [ ! -f ~/maketabs.sh ]; then echo '#!/bin/bash' > maketabs.sh ./autotab.sh pathtabs.list >> maketabs.sh chmod u+x maketabs.sh fi echo 'maketabs.sh: run xdotool command lines ONLY to open new tabs with pathtabs.list'
#run-maketabs? #./maketabs.sh
#remove-maketabs.sh?
#remove-autotab.sh? #rm autotab.sh
#remove-pathtabs.list? #rm pathtabs.list
#run-makepctabs? #./makepctabs.sh
#remove-makepctabs.sh? #rm makepctabs.sh
#remove-autopctab.sh? #rm autopctab.sh
#remove-pathncommtabs.list? #rm pathncommtabs.list
#remove-dirs? #rm -r foo_0?
#echo See also 'https://askubuntu.com/a/380320' #echo ' https://www.semicomplete.com/projects/xdotool/' #echo ' https://github.com/jordansissel/xdotool'
