OS: Ubuntu 18.04 or Kubuntu 18.04.
I have Gedit 3.28.1 on both systems. While looking at .bashrc or /etc/skel/.bashrc, I found an instance of "bracket match not found" as shown in the image below in both Ubuntu and Kubuntu:
Bracket match not found
Note that Gedit uses the same phrase for (), [], and {}
Line 97 (as in a default .bashrc) is this:
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
While the first instance is matched correctly (not shown in the image):
the second isn't:
The complete line is this:
Mousepad 0.4 also doesn't match the second instance whereas Geany 1.32 and Kate 17.12.3 do.
Do I need to install something to get Gedit and Mousepad to fix the "bracket match not found"? Or is it an issue with the algorithm used by these two text editors?
DK Bose
  • 44,553
