Every time I open my terminal, I see xyz@abc where I type my sudo commands.However, my concern is this xyz and I want to change it to the name of my choice. I am unaware of the technical term for this and also the steps to do this.I am using ubuntu 18.04.
What you see (xyz@abc) is the bash prompt:
  • xyz is the username
  • abc is the hostname
You can tune it by modifying the variable PS1 in the file ~/.bashrc. You may see the Ubuntu documentation: Customizing Bash Prompt.
Simply open ~/.bashrc file in a text editor like nano, create new line filled with a copy of the PS1 definition. For your need, you will replace the \u username tag by coco if you want to see coco in place of xyz.
Inside of ~/.bashrc:
if [ "$color_prompt" = yes ]; then
    #PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
    PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]coco@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
    #PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
    PS1='${debian_chroot:+($debian_chroot)}coco@\h:\w\$ '
fi
Some readings:
pa4080
  • 30,621
cmak.fr
  • 8,976
