How can I securely install and use Windows & Ubuntu in dual boot. What I mean is how can I avoid GRUB failures, bootloader being overwritten by Windows? Is there a best practice (maybe backing up or something else)?
Zanna
  • 72,312
Tosh
Firstly, make sure you install Windows BEFORE you install Ubuntu. The latest (at the time of writing) Windows 10 versions will probably break grub once you boot into Windows, but it can be prevented.
A solution I found somewhere online (unix.stackexchange.org) involves deactivating windows boot manager. Get into Linux (either the original install, if you can or live CD/DVD) and run this command:
efibootmgr
Note that this method will only work if Linux has been installed in UEFI mode, so you'll get an error if Linux has been installed in Legacy mode. If you installed it in UEFI mode, you'll get some info and a list. You'll notice Windows boot loader/manager and Linux somewhere in the list. It's likely that Windows will have higher priority (boot order is above the list).
There are also stars* beside some, if not all, of the entries, marking them active.
Look at the 4 digit boot number next to Windows entry and run
sudo efibootmgr --bootnum #### --inactive
This will deactivate Windows entry. Also, make sure that now deactivated Windows has higher priority if it doesn't already:
sudo efibootmgr --bootorder ####,$$$$,&&&&,%%%%
where #### is Windows boot number.
If you reboot now, you'll boot to grub, if the Linux option is enabled with the highest priority.
Note that Windows doesn't seem to recognize that it's been deactivated, so this will not get reverted by booting into Windows or updating it.
I participated in a local Linux installfest where we install Linux for interested people, most often as a secondary OS next to Windows. I've yet to see this method fail, and I've tried it on several distros (mostly Ubuntu and Mint) and several vendors (Asus, Acer, HP, Lenovo).
Karlovsky120
  • 303
For dual boot where you run one or the other, many are doing this with Windows and Ubuntu (I'm doing it with Win10 and Kubuntu 18.04). If you're not well experienced with Linux, you need to partition your drive into at least 2 sections and install Windows first, then Ubuntu. Ubuntu is smart and will see your Windows and then GRUB will create a menu where you can choose which OS to boot.
Compatico
  • 154
