I tried to follow the commands based on this link Download and Install Compass — MongoDB Compass stable
I have downloaded the package mongodb-compass_1.15.1_amd64.deb and tried installing using
sudo dpkg -i mongodb-compass_1.15.1_amd64.deb;
But I'm getting dependency problems:
(Reading database ... 195489 files and directories currently installed.)
Preparing to unpack mongodb-compass_1.15.1_amd64.deb ...
Unpacking mongodb-compass (1.15.1-1) ...
dpkg: dependency problems prevent configuration of mongodb-compass:
 mongodb-compass depends on libgconf-2-4; however:
  Package libgconf-2-4 is not installed.
dpkg: error processing package mongodb-compass (--install):
 dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
 mongodb-compass
How do I fix installation error in Ubuntu?
Kulfy
  • 18,154
I encountered the same error. However, when I installed it using Software Center it was successfully installed. To install it using Software Center, double click on the .deb package and Click install.
Use sudo apt install -f to fix dependency problems.
Also its better to install it using APT like
sudo apt install ./filename
Differences between APT and DPKG are described here: What is the difference between dpkg and aptitude/apt-get?
Kulfy
  • 18,154
Run sudo apt --fix-broken install
then
`sudo dpkg -i mongodb-compass_1.15.1_amd64.deb;`
This will fix the problem.
