-1
I have a purple screen on my Ubuntu and I am unable to log in. Please help. Thanks........ I have tried numerous times to try fix this problem.
first time, after installing it? I had the same issue with 18.04 when I installed when I first needed to login it will get stuck on a purple screen... they way I got arround that is re-installed the system and then check the option box "autologin" so it login without needing a password and then I was able to use the system.
The problem at least on my laptop was fixed with the version 18.04.01..
I don't know if that helps you or not XD
