Apparently Ubuntu 11.10 uses Vim when I type
vi filename
How do I force Ubuntu to use Vi instead?
vi filename
You need to install the actual vi package, which is nvi on Ubuntu.
sudo apt-get install nvi
You might also need to run the line below if nvi isn't picked up automatically as the default provider for vi.
sudo update-alternatives --config vi
Check out:
Decide which vi-compatible tool you want to use.
vim, elvis, nvi, vigor (etc). You may want to study the output of apt-cache search editor |grep vi and look for other alternatives. nvi claims to be "bug for bug" compatible with vi.
Once you've done that, install the package:
apt-get install $YOURCHOICE
then run
and choose $YOURCHOICE as the one to set as "vi".
If by any chance you just want to get rid of Vim specific features, you can also make sure that Vim runs in compatible mode.
By default, when you type vi in Ubuntu, it actually runs Vim, because over time the Linux OSs have updated and some are now using Vim. If you still want to use vi, you have to install the package that directly runs vi instead of vim.
To install just vi:
sudo apt install nvi
You can also use vim-tiny (preinstalled.)
Another solution is to type busybox vi in the terminal. This brings the default Vi installed on 18.04/18.10. This version is a very small clone of vi.
If you want to make it your default for when you type editor, type sudo update-alternatives --config editor. To make it the default for when you type edit, add export EDITOR="/usr/bin/nvi" to your .bashrc file.
vim is set as your default editor. Put this as your default editor by setting this environment variable--> export EDITOR=vi
