When I play music in ncmpcpp, youtube videos do not work (vice versa)
I can only play one at a time, why is that? How do I fix it?
on macOS I could play ncmpcpp and youtube videos at the same time, and now I'm curious as to why.
(update a week later: For anyone who finds this in the future, I decided to use cmus + cava as a workaround, since cmus works with everything else.)
update three weeks later: cmus + vis works fine, you just gotta compile cli-visualizer with pulse. https://github.com/dpayne/cli-visualizer#pulse-audio-setup-easy
update a month later: I found the solution, it's this answer right here: https://askubuntu.com/a/555484/913725
ums
  • 153
To solve this you must load a module with pulse audio control:
pactl load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1
after putting
audio_output {
   type     "pulse"
   name     "My PULSE Device"
   server   "127.0.0.1"
in /etc/mpd.conf
You can pactl unload-module module-native-protocol-tcp to unload the module.
ums
  • 153
The problem is in your audio output, Just go to your mpd.conf and comment out the pulse audio part and comment in Alsa audio output. Then restart mpd, it should work!
Nomi Shaw
  • 455
