13
I'm accessing a fresh install of Ubuntu 18.10 and Samba 4.8.4 from macOS clients running Mojave. When connected via SMB, I want the Finder icon to look like a Mac Mini (because that's what Ubuntu 18.10 is running on).
In /etc/samba/smb.conf ([global] section), these values for fruit:model worked:
  • Xserve
  • MacPro
  • iMac
All of these values also work, but resulted in the default icon (that looks like an Apple Cinema Display):
  • MacBook
  • MacMini
  • MacSamba
  • TimeCapsule
  • RackMac
Saw a post recommending model names from /System/Library/CoreServices/CoreTypes.bundle/Contents/Info.plist on a Mac. While there are many there, the ones I tried didn't work.
Re: avahi-daemon, Samba 4.8.4 can set the icon for connected macOS clients without avahi-daemon running (worked for the three models above). While having avahi-daemon helps the server be perpetually visible in the Finder, I'm trying to understand only the working values for fruit:model in the smb.conf.
Anyone have any insight?
Alexander
  • 159
There are plenty of other model strings that should work as values; I believe they are directly read from /System/Library/CoreServices/CoreTypes.bundle/Contents/Info.plist.
Browsing through that file, you should be able to intuit valid values. For example, from the line
UTTypeTagSpecification = { com.apple.device-model-code = ( "Macmini", "Macmini5", "Macmini6", "Macmini7" ); };
I deduced that the proper string for the Mac Mini is Macmini (no CamelCase). MacBook should work, though. As should AppleTV, MacBook5,2, and many more appearing in the aforementioned file.
Leeron R
  • 71
One can use the following python script to get the latest available models.
import plistlib
from contextlib import suppress
types = plistlib.load(open("/System/Library/CoreServices/CoreTypes.bundle/Contents/Info.plist", "rb"))
models = [] for uttype in types['UTExportedTypeDeclarations']: with suppress(KeyError): model = uttype['UTTypeTagSpecification']['com.apple.device-model-code'] if isinstance(model, str): models.append(model) else: models.extend(model) fmt = "" i = 4 models.sort() prev = models[0][:i]
for model in models: if prev != (prev:=model[:i]): fmt += "\n\n" fmt += f"{model}, "
print(fmt)
The currently available values for the 'fruit:model' parameter are:
ADP2,1,
ADP3,2,
AirPort, AirPort4, AirPort4,102, AirPort4,107, AirPort5, AirPort5,104, AirPort5,105, AirPort5,108, AirPort5,114, AirPort5,117, AirPort6, AirPort6,106, AirPort7,120,
AppleTV, AppleTV1,1,
D201AP, D201AP, D201AP,
D20AP, D20AP, D20AP,
D211AP, D211AP, D211AP,
D21AP, D21AP, D21AP,
D221AP, D221AP,
D22AP, D22AP,
K48AP,
Laptop,
M68AP,
MacBook, MacBook1,1, MacBook1,1,Black, MacBook1,1,White, MacBook10,1@ECOLOR=157,157,160, MacBook10,1@ECOLOR=217,180,154, MacBook10,1@ECOLOR=225,225,223, MacBook10,1@ECOLOR=232,201,195, MacBook10,1@ECOLOR=235,215,191, MacBook2,1, MacBook2,1,Black, MacBook2,1,White, MacBook3,1, MacBook3,1,Black, MacBook3,1,White, MacBook4,1, MacBook4,1,Black, MacBook4,1,White, MacBook5,1, MacBook5,2, MacBook6,1, MacBook7,1, MacBook8,1, MacBook8,1@ECOLOR=155,158,159, MacBook8,1@ECOLOR=157,157,160, MacBook8,1@ECOLOR=225,225,223, MacBook8,1@ECOLOR=235,215,191, MacBook9,1, MacBook9,1@ECOLOR=157,157,160, MacBook9,1@ECOLOR=225,225,223, MacBook9,1@ECOLOR=232,201,195, MacBook9,1@ECOLOR=235,215,191, MacBookAir, MacBookAir1,1, MacBookAir10,1, MacBookAir10,1@ECOLOR=1, MacBookAir10,1@ECOLOR=2, MacBookAir10,1@ECOLOR=3, MacBookAir2,1, MacBookAir3,1, MacBookAir3,2, MacBookAir4,1, MacBookAir4,2, MacBookAir5,1, MacBookAir5,2, MacBookAir6,1, MacBookAir6,2, MacBookAir7,1, MacBookAir7,2, MacBookAir8,1, MacBookAir8,1@ECOLOR=157,157,160, MacBookAir8,1@ECOLOR=217,180,154, MacBookAir8,1@ECOLOR=225,225,223, MacBookAir8,2, MacBookAir8,2@ECOLOR=157,157,160, MacBookAir8,2@ECOLOR=217,180,154, MacBookAir8,2@ECOLOR=225,225,223, MacBookAir9,1, MacBookAir9,1@ECOLOR=157,157,160, MacBookAir9,1@ECOLOR=217,180,154, MacBookAir9,1@ECOLOR=225,225,223, MacBookPro, MacBookPro1,1, MacBookPro1,2, MacBookPro10,1, MacBookPro10,2, MacBookPro11,1, MacBookPro11,2, MacBookPro11,3, MacBookPro11,4, MacBookPro11,5, MacBookPro12,1, MacBookPro13,1, MacBookPro13,1@ECOLOR=157,157,160, MacBookPro13,1@ECOLOR=225,225,223, MacBookPro13,2, MacBookPro13,2@ECOLOR=157,157,160, MacBookPro13,2@ECOLOR=225,225,223, MacBookPro13,3, MacBookPro13,3@ECOLOR=157,157,160, MacBookPro13,3@ECOLOR=225,225,223, MacBookPro14,1, MacBookPro14,1@ECOLOR=157,157,160, MacBookPro14,1@ECOLOR=225,225,223, MacBookPro14,2, MacBookPro14,2@ECOLOR=157,157,160, MacBookPro14,2@ECOLOR=225,225,223, MacBookPro14,3, MacBookPro14,3@ECOLOR=157,157,160, MacBookPro14,3@ECOLOR=225,225,223, MacBookPro15,1, MacBookPro15,1@ECOLOR=157,157,160, MacBookPro15,1@ECOLOR=225,225,223, MacBookPro15,2, MacBookPro15,2@ECOLOR=157,157,160, MacBookPro15,2@ECOLOR=225,225,223, MacBookPro15,3, MacBookPro15,3@ECOLOR=157,157,160, MacBookPro15,3@ECOLOR=225,225,223, MacBookPro15,4, MacBookPro15,4@ECOLOR=157,157,160, MacBookPro15,4@ECOLOR=225,225,223, MacBookPro16,1, MacBookPro16,1@ECOLOR=157,157,160, MacBookPro16,1@ECOLOR=225,225,223, MacBookPro16,2, MacBookPro16,2@ECOLOR=157,157,160, MacBookPro16,2@ECOLOR=225,225,223, MacBookPro16,3, MacBookPro16,3@ECOLOR=157,157,160, MacBookPro16,3@ECOLOR=225,225,223, MacBookPro16,4, MacBookPro16,4@ECOLOR=157,157,160, MacBookPro16,4@ECOLOR=225,225,223, MacBookPro17,1, MacBookPro17,1@ECOLOR=1, MacBookPro17,1@ECOLOR=2, MacBookPro2,1, MacBookPro2,2, MacBookPro3,1, MacBookPro4,1, MacBookPro5,1, MacBookPro5,2, MacBookPro5,3, MacBookPro5,4, MacBookPro5,5, MacBookPro6,1, MacBookPro6,2, MacBookPro7,1, MacBookPro8,1, MacBookPro8,2, MacBookPro8,3, MacBookPro9,1, MacBookPro9,2,
MacPro, MacPro1,1, MacPro2,1, MacPro3,1, MacPro4,1, MacPro5,1, MacPro6,1, MacPro7,1, MacPro7,1@ECOLOR=225,225,223, MacPro7,1@ECOLOR=226,226,224,
Macintosh,
Macmini, Macmini1,1, Macmini2,1, Macmini3,1, Macmini4,1, Macmini5, Macmini6, Macmini7, Macmini8,1, Macmini9,1,
N18AP,
N45AP,
N72AP,
N81AP,
N82AP,
N88AP,
N90AP,
PowerBook, PowerBook3,2, PowerBook3,3, PowerBook3,4, PowerBook3,5, PowerBook5,1, PowerBook5,2, PowerBook5,3, PowerBook5,4, PowerBook5,5, PowerBook5,6, PowerBook5,7, PowerBook5,8, PowerBook5,9, PowerBook6,1, PowerBook6,2, PowerBook6,3, PowerBook6,4, PowerBook6,5, PowerBook6,7, PowerBook6,8, PowerMac, PowerMac10,1, PowerMac10,2, PowerMac11,2, PowerMac11,2,Quad, PowerMac12,1, PowerMac3,5, PowerMac3,6, PowerMac4,2, PowerMac4,4, PowerMac4,5, PowerMac6,1, PowerMac6,3, PowerMac6,4, PowerMac7,2, PowerMac7,3, PowerMac8,1, PowerMac8,2, PowerMac9,1,
RackMac, RackMac1,1, RackMac1,2, RackMac3,1, RackMount,
TimeCapsule, TimeCapsule6, TimeCapsule6,106, TimeCapsule6,109, TimeCapsule6,113, TimeCapsule6,116, TimeCapsule8,119,
Tower,
Watch,
Windows, Windows2000, Windows2003, Windows2008, Windows7, WindowsVista, WindowsXP,
Xserve, Xserve1,1, Xserve2,1, Xserve3,1,
iMac, iMac10,1, iMac11,1, iMac11,2, iMac11,3, iMac12,1, iMac12,2, iMac13,1, iMac13,2, iMac13,3, iMac14,1, iMac14,2, iMac14,3, iMac14,4, iMac15,1, iMac16,1, iMac16,2, iMac17,1, iMac18,1, iMac18,2, iMac18,3, iMac19,1, iMac19,2, iMac20,1, iMac20,2, iMac21,1, iMac21,1@ECOLOR=1, iMac21,1@ECOLOR=3, iMac21,1@ECOLOR=4, iMac21,1@ECOLOR=5, iMac21,1@ECOLOR=6, iMac21,1@ECOLOR=7, iMac21,1@ECOLOR=8, iMac21,2, iMac21,2@ECOLOR=1, iMac21,2@ECOLOR=4, iMac21,2@ECOLOR=5, iMac21,2@ECOLOR=6, iMac4,1, iMac4,2, iMac5,1, iMac5,2, iMac6,1, iMac7,1, iMac8,1, iMac9,1, iMacPro1,1,
iPad, iPad1,1,
iPhone, iPhone, iPhone, iPhone, iPhone, iPhone, iPhone, iPhone, iPhone, iPhone1,1, iPhone1,2, iPhone10,1, iPhone10,1, iPhone10,1, iPhone10,2, iPhone10,2, iPhone10,2, iPhone10,3, iPhone10,3, iPhone10,4, iPhone10,4, iPhone10,4, iPhone10,5, iPhone10,5, iPhone10,5, iPhone10,6, iPhone10,6, iPhone2,1, iPhone3,1,
iPod, iPod1,1, iPod2,1, iPod3,1, iPod4,1
Remember to restart samba and avahi:
sudo service smbd restart
sudo avahi-daemon -k
As well as your Finder by clicking on the Finder while holding Ctrl + Option in that order.
I also had to put the 'fruit:model' parameter in the global section of my 'smb.conf'.
Alexander
  • 159
Plist: /System/Library/CoreServices/CoreTypes.bundle/Contents/Info.plist
Icons: /System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/*.icns
