Trying to learn more about Kubernetes I tried to install a standalone instance. If you try to run minikube terminal? suggest installing it through snap.
sudo snap install minikube kubectl
  • snap info minikube
    Minikube is a tool that makes it easy to run Kubernetes locally. Minikube runs a single-node Kubernetes cluster inside a VM on your laptop for users looking to try out Kubernetes or develop with it day-to-day.
  • snap info kubectl
    kubectl is a command line interface for running commands against Kubernetes
But that let me with this error:
$ minikube start
There is a newer version of minikube available (v0.32.0).  Download it here:
https://github.com/kubernetes/minikube/releases/tag/v0.32.0
To disable this notification, add WantUpdateNotification: False to the json config file at /home/pablo/snap/minikube/4/.minikube/config
(you may have to create the file config.json in this folder if you have no previous configuration)
Starting local Kubernetes cluster...
E0113 21:27:07.861621   12532 start.go:83] Error starting host: Error creating new host: dial tcp: missing address. Retrying.
E0113 21:27:07.876969   12532 start.go:83] Error starting host: Error creating new host: dial tcp: missing address. Retrying.
E0113 21:27:07.892771   12532 start.go:83] Error starting host: Error creating new host: dial tcp: missing address. Retrying.
E0113 21:27:07.892806   12532 start.go:89] Error starting host:  Error creating new host: dial tcp: missing address
I tried:
  • Almost all suggestions on Github issues: 278, 867, 927, 2294, 2424.
  • Installing (already there) libvirt-bin (libvirt-clients libvirt-daemon)
  • sudo virsh -c qemu:///system net-start default
Maybe not ready for prime time?
Pablo Bianchi
  • 17,371
I finally found a working solution, removing the snap package (sudo snap remove minikube) and then following one of the official guides keeping kubectl:
curl -LO "https://github.com/kubernetes/minikube/releases/latest/download/minikube-linux-amd64"
sudo install minikube-linux-amd64 /usr/local/bin/minikube && rm minikube-linux-amd64
Also, you could go the Debian-package way
curl -LO "https://storage.googleapis.com/minikube/releases/latest/minikube_latest_amd64.deb"
sudo dpkg -i minikube_latest_amd64.deb
Then start the cluster with minikube start.
Tested with kubectl version and
$ kubectl get nodes
NAME       STATUS   ROLES    AGE   VERSION
minikube   Ready    master   25m   v1.12.4
To run the dashboard just
minikube dashboard
Alternatively you could try microk8s (add-ons, ARM, multi-node), kind or k3s. You might be also interested in Nomad.
Pablo Bianchi
  • 17,371
