10
How can I install Filezilla on Linux 18.04 via command line, kindly help.
sudo sh -c 'echo "deb http://archive.getdeb.net/ubuntu xenial-getdeb apps" >> /etc/apt/sources.list.d/getdeb.list'
wget -q -O - http://archive.getdeb.net/getdeb-archive.key | sudo apt-key add -
sudo apt update
sudo apt install filezilla
while running sudo apt-get update i m getting this errors
Hit:8 https://download.sublimetext.com apt/stable/ InRelease
Err:3 http://www.getdeb.net/ubuntu yakkety-getdeb InRelease
  403  Forbidden [IP: 143.95.32.90 80]
Err:9 http://ppa.launchpad.net/adabbas/1stppa/ubuntu bionic Release
  404  Not Found [IP: 91.189.95.83 80]
E: Failed to fetch http://archive.getdeb.net/ubuntu/dists/yakkety-getdeb/InRelease  403  Forbidden [IP: 143.95.32.90 80]
E: The repository 'http://ppa.launchpad.net/n-muench/programs-ppa/ubuntu bionic Release' does not have a Release file.
W: Target Translations (apps/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:1 and /etc/apt/sources.list.d/getdeb.list:2
Terrance
  • 43,712
vicky
  • 109
FileZilla is not installed by default, To install FileZilla on Ubuntu 18.04, Open the terminal and execute:
sudo apt-get update
sudo apt-get install filezilla
Connecting to the FTP server with FileZilla
To connect to a FTP Server, Open the FileZilla FTP client and type the domain name or IP address of the FTP server in the Host field. Provide the FTP username and password and FTP port( you can leave the port empty if your server use default FTP port 21) and click on Quick connect button.
I would recommend a clean installation from the repository 'universe' in Ubuntu 18.04.1 LTS. You may have to remove everything that smells of 'xenial', 'yakkety' or any other previous version in order to keep 18.04 alias 'bionic' clean.
In an installed system 'universe' is already active, but in a live or persistent live system of standard Ubuntu, you must run
sudo add-apt-repository universe
and after that you can install filezilla and many other program packages
sudo apt update
I tested now (in a persistent live Ubuntu 18.04.1 LTS) and it works. I get a working version of filezilla.
sudodus
  • 47,684
