I seem to be able to hibernate OK using s2disk, but when I switch the laptop back on, it seems to hang half-way through the "resuming" menu. The splash screen looks healthy, it seems to be trying to resume from the correct disk, but it hangs about half-way through, with three little pips.
One great help would be - where can I find the logs, and how do I get more verbose ones?
There is some info in /var/log/pm-suspend.log, but that all seems fine, just lots of hibernate: success messages...
How do I switch on more verbose logging in s2disk? And what about the resume process, where are the logs for that, and how can I make them more detailed?
Background: the standard Ubuntu hibernate wouldn't work, so I've install uswusp and its associated tools - s2disk etc. That initially made things worse, but a fair amount of fiddling with its config, my swap size and so on seem to have got it at least seemingly successfully suspending...
[update] some config info:
RAM: 8GB swap space: 8.63GiB (NB i did try increasing swap to 16GB, didn't help)
$ sudo blkid
/dev/sda: TYPE="isw_raid_member"
/dev/zram0: UUID="45e58d74-be57-4ad4-95de-217e9ba7d087" TYPE="swap"
/dev/sdb: TYPE="isw_raid_member"
/dev/mapper/isw_dgibfidibf_Volume0p1: LABEL="Ubuntu" UUID="7ca86fcb-a969-45d5-b67f-fe29bc568f4d" TYPE="ext4"
/dev/mapper/isw_dgibfidibf_Volume0p2: LABEL="System Reserved" UUID="2A1A38861A3850D5" TYPE="ntfs"
/dev/mapper/isw_dgibfidibf_Volume0p3: LABEL="Windows" UUID="FE6C39286C38DD59" TYPE="ntfs"
/dev/mapper/isw_dgibfidibf_Volume0p5: UUID="dfb8af38-acf1-42be-be18-131d326a21ff" TYPE="swap"
/dev/mapper/isw_dgibfidibf_Volume0p6: LABEL="SHARED" UUID="10BA-FE58" TYPE="vfat"
$ cat /etc/initramfs-tools/conf.d/resume
RESUME=/dev/mapper/isw_dgibfidibf_Volume0p5
[update 2] - have followed instructions at https://wiki.ubuntu.com/DebuggingKernelSuspendHibernateResume and submitted a bug report: https://bugs.launchpad.net/ubuntu/+source/hibernate/+bug/987109
hwjp
  • 1,457
try removing cryptsetup from your system, worked for me.
h951535
This answer may not be helpful for around 7 days, but I had a similar problem with hibernate and sleep and when I upgraded to Ubuntu 12.04 Beta all issues were solved. So I'd suggest either simply waiting till April 26th and upgrade then or Installing Ubuntu 12.04 Beta.
Hope this helps.
Ross Fleming
  • 1,041
