This is a very odd problem I've been experiencing lately, it seems to happen a lot and i'm very worried things are gonna start breaking worse than they have already. This problem has happened a lot but here is just one example:
sudo apt-get install openvpn-systemd-resolved
Here's the output:
Reading package lists... Done
Building dependency tree
 openvpn-systemd-resolved : Depends: libnss-resolve but it is not going to be installed
And when i try sudo apt-get install libnss-resolve
This is what i get:
 libnss-resolve : Depends: systemd (= 237-3ubuntu10.3)
But systemd is obviously installed with a higher version!
apt show systemd
Shows me that:
Package: systemd
Version: 237-3ubuntu10.9
Status: install ok installed
I need a fix for this problem as soon as possible.. I haven't been able to install a lot of packages because there always seems to be a "you have held broken packages." message popping up.
And YES before you say it, I've already tried all of these(without any error output):
sudo apt --fix-broken install
sudo dpkg --configure --pending
sudo dpkg --configure -a
sudo apt-get -f install
sudo apt update --fix-missing
This has happened once before with libgtk-3-0 and removing/reinstalling the package did eventually work but you can imagine the pain i had to go through to fix everything after removing it(libgtk-3-0 is a dependency for a lot of other packages). Is there a fix? downgrading my packages, especially core ones like systemd is the last thing i want to do.
Xosrov
  • 73
