I cannot update anything or install new software because of problems with the dependencies. The terminal suggest to run apt-get -f install. After trying this, there is a problem saying that it failed to correct efficiencies. Then it says:
update-notifier : Depends: update-notifier-common (= 3.168.9) but 3.168.8 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
I have tried some of the solutions to similar problems posted in here but all have been futile. One of them said to look at the log file and try to remove the "broken" packages... but my log file was blank...
** UPDATE **
I ran the command sudo apt-cache policy update-notifier update-notifier-common This was the output:
update-notifier:
Installed: 3.168.9
Candidate: 3.192.1.4
Version table:
3.192.1.4 500
500 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
3.192 500
500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
*** 3.168.9 100
100 /var/lib/dpkg/status
3.168.7 500
500 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages
3.168 500
500 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
update-notifier-common:
Installed: 3.168.8
Version table:
3.192.1.4 500
500 http://us.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages
3.192 500
500 http://us.archive.ubuntu.com/ubuntu bionic/main i386 Packages
*** 3.168.8 100
3.168.7 500
500 **security.ubuntu**/ubuntu xenial-security/main amd64 Packages
500 **security.ubuntu**/ubuntu xenial-security/main i386 Packages
3.168 500
500 **archive.ubuntu**/ubuntu xenial/main amd64 Packages
500 **archive.ubuntu**/ubuntu xenial/main i386 Packages
Note : the last 4 links are modified. They should start with http:// and after ".ubuntu" should have a .com . However, I can only include up to 8 links.
