I've installed Ubuntu 18.04.
I've installed tesseract using sudo apt-get install tesseract-ocr
When I type:
tesseract -v
I had an error:
tesseract: symbol lookup error: /usr/lib/x86_64-linux-gnu/libtesseract.so.4: undefined symbol: pixaDisplayTiledInColumns
Below is the output of apt-cache policy tesseract-ocr:
Installed: 4.00~git2288-10f4998a-2
Candidate: 4.00~git2288-10f4998a-2
Version table:
   *** 4.00~git2288-10f4998a-2 500
          500 in.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
          100 /var/lib/dpkg/status
N0rbert
  • 103,263
This is a bug of tesseract package, which is found in release 4.00~git2481-555f6ffc-1. Do this:
sudo apt install libtesseract-dev libleptonica-dev liblept5
tesseract -v
If it did not help, just build tesseract from source...
Update 1: You can do
sudo apt purge tesseract* libtesseract*
sudo apt autoremove --purge
to remove everything that belongs to tesseract with configurations. However, it may also remove dependant packages, such as opencv (depends to libtesseract4)
Olimjon
  • 7,522
On my clean Ubuntu 18.04 LTS VM with all updates Tesseract installs without any issues.
So it is completely operable.
The linked bug by @Olimjon is not related to current problem as it was reported after 18.04 LTS feature freeze.
On my system I have done the following:
$ sudo apt install tesseract-ocr -y
and got
$ tesseract -v
tesseract 4.0.0-beta.1
 leptonica-1.75.3
  libgif 5.1.4 : libjpeg 8d (libjpeg-turbo 1.5.2) : libpng 1.6.34 : libtiff 4.0.9 : zlib 1.2.11 : libwebp 0.6.1 : libopenjp2 2.3.0
Found AVX Found SSE
$ apt-cache policy tesseract-ocr tesseract-ocr: Installed: 4.00~git2288-10f4998a-2 Candidate: 4.00~git2288-10f4998a-2 Version table: *** 4.00~git2288-10f4998a-2 500 500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages 100 /var/lib/dpkg/status
So, if @mayurpanchal really want to solve Tesseract problem - then please update all packages in your system and install tesseract-ocr again and add requested output of ldd /usr/lib/x86_64-linux-gnu/libtesseract.so.4 to the question.
It may be PPA or third-party libraries issue.
N0rbert
  • 103,263
Here is the solution for ubuntu 18.04
Please first install the libraries which are required for tesseract-ocr
Then simply install tesseract using command
Hassan ALi
  • 183
