I have UBUNTU 16.04.05 LTS X64 and when I try to add any repositories I'm having the following error!
for example I have used: sudo add-apt-repository ppa:noobslab/apps and the result is:
This PPA Contains Applications for Ubuntu/Linux Mint from different sources but debianized by http://www.NoobsLab.com
More info: https://launchpad.net/~noobslab/+archive/ubuntu/apps
Press [ENTER] to continue or ctrl-c to cancel adding it
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 168, in <module>
if not sp.add_source_from_shortcut(shortcut, options.enable_source):
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 768, in add_source_from_shortcut
self.set_modified_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 492, in set_modified_sourceslist
self.save_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 658, in save_sourceslist
self.sourceslist.save()
File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 413, in save
files[source.file] = open(source.file, "w")
FileNotFoundError: [Errno 2] No such file or directory: '/etc/apt/sources.list.d/noobslab-ubuntu-apps-xenial.list'
gpg: keyring `/tmp/tmph_0b92bg/secring.gpg' created
gpg: keyring `/tmp/tmph_0b92bg/pubring.gpg' created
gpg: requesting key F59EAE4D from hkp server keyserver.ubuntu.com
gpg: /tmp/tmph_0b92bg/trustdb.gpg: trustdb created
gpg: key F59EAE4D: public key "Launchpad PPA for NoobsLab" imported
gpg: no ultimately trusted keys found
gpg: Total number processed: 1
gpg: imported: 1 (RSA: 1)
gpg: keyblock resource `/etc/apt/trusted.gpg.d/noobslab_ubuntu_apps.gpg': file open error
gpg: no writable keyring found: eof
gpg: error reading `/tmp/tmph_0b92bg/pubring.gpg': general error
gpg: import from `/tmp/tmph_0b92bg/pubring.gpg' failed: general error
it always gives me this error with any sort of repositories that I try to add. I have tried many solutions I'm going to list them below:
Error : Running add-apt repository ppa:
How to install certificates for command line
Permission denied: '/etc/apt/sources.list.d/google-earth.list'
and many many other solutions given to related problems. no one worked for me.
is there any solutions here?
regards
output of file /etc/apt/sources.list is shown below:
/etc/apt/sources.list: ASCII text
