When I try to install some package, I get this output:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.13.0-45-generic : Depends: linux-image-4.13.0-45-generic but it is not going to be installed
linux-image-generic-hwe-16.04 : Depends: linux-image-4.15.0-43-generic but it is not going to be installed
linux-modules-extra-4.15.0-38-generic : Depends: linux-image-4.15.0-38-generic but it is not going to be installed or
linux-image-unsigned-4.15.0-38-generic but it is not going to be installed
linux-modules-extra-4.15.0-39-generic : Depends: linux-image-4.15.0-39-generic but it is not going to be installed or
linux-image-unsigned-4.15.0-39-generic but it is not going to be installed
linux-modules-extra-4.15.0-43-generic : Depends: linux-image-4.15.0-43-generic but it is not going to be installed or
linux-image-unsigned-4.15.0-43-generic but it is not going to be installed
ubuntu-cleaner : Depends: python-defer but it is not installable
Depends: python-lxml but it is not going to be installed
Depends: python-dbus but it is not going to be installed
Depends: python-aptdaemon but it is not installable
Depends: python-aptdaemon.gtk3widgets but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
UPD: result of - sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
dbconfig-common gyp javascript-common libaio1 libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libevent-core-2.0-5 libjs-inherits libjs-jquery libjs-node-uuid libjs-sphinxdoc
libjs-underscore liblua5.1-0 libmcrypt4 libssl-dev libssl-doc libuv1 libuv1-dev linux-headers-4.13.0-36 linux-headers-4.13.0-36-generic linux-headers-4.13.0-38 linux-headers-4.13.0-38-generic
linux-headers-4.13.0-45 linux-headers-4.13.0-45-generic linux-headers-4.15.0-38 linux-headers-4.15.0-38-generic linux-headers-4.15.0-39 linux-headers-4.15.0-39-generic linux-image-4.13.0-36-generic
linux-image-4.13.0-38-generic linux-image-4.13.0-45-generic linux-image-4.15.0-38-generic linux-image-4.15.0-39-generic linux-image-extra-4.13.0-36-generic linux-image-extra-4.13.0-38-generic
linux-image-extra-4.13.0-45-generic linux-modules-4.15.0-38-generic linux-modules-4.15.0-39-generic linux-modules-extra-4.15.0-38-generic linux-modules-extra-4.15.0-39-generic python-pkg-resources
zlib1g-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
linux-image-4.13.0-45-generic linux-image-4.15.0-38-generic linux-image-4.15.0-39-generic linux-image-4.15.0-43-generic linux-modules-4.15.0-39-generic linux-modules-4.15.0-43-generic
Suggested packages:
fdutils linux-tools linux-hwe-tools
The following NEW packages will be installed:
0 upgraded, 6 newly installed, 0 to remove and 400 not upgraded.
18 not fully installed or removed.
Need to get 0 B/70,4 MB of archives.
After this operation, 228 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 465767 files and directories currently installed.)
Preparing to unpack .../linux-modules-4.15.0-43-generic_4.15.0-43.46~16.04.1_amd64.deb ...
Unpacking linux-modules-4.15.0-43-generic (4.15.0-43.46~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-modules-4.15.0-43-generic_4.15.0-43.46~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.15.0-43-generic' to '/boot/System.map-4.15.0-43-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack .../linux-image-4.15.0-43-generic_4.15.0-43.46~16.04.1_amd64.deb ...
Unpacking linux-image-4.15.0-43-generic (4.15.0-43.46~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.15.0-43-generic_4.15.0-43.46~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.15.0-43-generic' to '/boot/vmlinuz-4.15.0-43-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../linux-image-4.13.0-45-generic_4.13.0-45.50~16.04.1_amd64.deb ...
Examining /etc/kernel/preinst.d/
run-parts: executing /etc/kernel/preinst.d/intel-microcode 4.13.0-45-generic /boot/vmlinuz-4.13.0-45-generic
Done.
Unpacking linux-image-4.13.0-45-generic (4.13.0-45.50~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.13.0-45-generic_4.13.0-45.50~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.13.0-45-generic' to '/boot/vmlinuz-4.13.0-45-generic.dpkg-new': failed to write (No space left on device)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.13.0-45-generic /boot/vmlinuz-4.13.0-45-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.13.0-45-generic /boot/vmlinuz-4.13.0-45-generic
Preparing to unpack .../linux-image-4.15.0-38-generic_4.15.0-38.41~16.04.1_amd64.deb ...
Unpacking linux-image-4.15.0-38-generic (4.15.0-38.41~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.15.0-38-generic_4.15.0-38.41~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.15.0-38-generic' to '/boot/vmlinuz-4.15.0-38-generic.dpkg-new': failed to write (No space left on device)
No apport report written because MaxReports is reached already
Preparing to unpack .../linux-modules-4.15.0-39-generic_4.15.0-39.42~16.04.1_amd64.deb ...
Unpacking linux-modules-4.15.0-39-generic (4.15.0-39.42~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-modules-4.15.0-39-generic_4.15.0-39.42~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.15.0-39-generic' to '/boot/System.map-4.15.0-39-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../linux-image-4.15.0-39-generic_4.15.0-39.42~16.04.1_amd64.deb ...
Unpacking linux-image-4.15.0-39-generic (4.15.0-39.42~16.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.15.0-39-generic_4.15.0-39.42~16.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.15.0-39-generic' to '/boot/vmlinuz-4.15.0-39-generic.dpkg-new': failed to write (No space left on device)
UPD2: result of - df -h
226M 220M 0 100% /boot
result of - du -h --max-depth=1 /boot
120M /boot/.Trash-0
6,8M /boot/grub
12K /boot/lost+found
218M /boot
But if I open folder properties in nautilus, I see a different size
307 items, totalling 102,2 MB (some contents unreadable)
result of ls - total 93009
UPD3: All commands with apt, apt-get or dpkg) give these errors:
linux-headers-4.15.0-38-generic : Depends: linux-headers-4.15.0-38 but it is not going to be installed
linux-image-extra-4.13.0-36-generic : Depends: linux-image-4.13.0-36-generic but it is not going to be installed
linux-image-extra-4.13.0-38-generic : Depends: linux-image-4.13.0-38-generic but it is not going to be installed
linux-image-extra-4.13.0-41-generic : Depends: linux-image-4.13.0-41-generic but it is not going to be installed
linux-image-extra-4.13.0-43-generic : Depends: linux-image-4.13.0-43-generic but it is not going to be installed
