10
I try to login Ubuntu 16.04 xrdp through window 10 with mstsc. It was successful in 2019/01/09 night, but failed in 2019/01/10 morning. An system auto-update log relating to xrdf is captured.
Connection log is listed below:
connecting to sesman ip 127.0.0.1 port 3350
sesman connect ok
seding login info to session manager, please wait...
xrdp_mm_process_login_response: login successful for display
started connecting
connecting to 127.0.0.1 5916
tcp connected
security level is 2 (1=none, 2=standard)
password failed
error - problem connecting
System update log is captured and shown below:
2019-01-10 02:31:21 status installed systemd:amd64 229-4ubuntu21.10
2019-01-10 02:31:21 status installed ureadahead:amd64 0.100.0-19
2019-01-10 02:31:22 status installed man-db:amd64 2.7.5-1
2019-01-10 02:31:22 status installed xrdp:amd64 0.6.1-2ubuntu0.1
2019-01-10 02:31:22 status installed libnss3-nssdb:all 2:3.28.4-0ubuntu0.16.04.4
2019-01-10 02:31:22 status installed libnss3:amd64 2:3.28.4-0ubuntu0.16.04.4
2019-01-10 02:31:22 status installed libnss3:i386 2:3.28.4-0ubuntu0.16.04.4
2019-01-10 02:31:22 status installed libc-bin:amd64 2.23-0ubuntu10
Hence, I deduce that xrdp or its related package was influenced by system update. Then methods[1-3] were tried but failed.
  1. Change password. http://xrdp-devel.766250.n3.nabble.com/Xrdp-devel-Need-a-little-help-td4024769.html
  2. Replace vnc4server with tightvncserver. https://raspberrypi.stackexchange.com/questions/56413/error-problem-connecting-to-raspberry-pi-3-with-xrdp
  3. Kill orphaned process. https://unix.stackexchange.com/questions/106974/windows-remote-desktop-login-failed-with-ubuntu-server-12-4
So, any idea to solve this problem ?
Tripod
  • 101
6 Answers6
12
Check /var/log/apt/history.log, this was part of the upgrade from this morning (2019-01-10)
xrdp:amd64 (0.6.1-2, 0.6.1-2ubuntu0.1)
I then downgraded:
sudo apt-get install xrdp=0.6.1-2
It now works
Pablo Bianchi
  • 17,371
This seems like there are some security improvements in xrdp which may not be completely mirrored in vnc (either the software or its config), which is why reverting to the older version works.
A workaround from the Ubuntu bug tracker issue for this:
Adding this in sesman.ini under [Xvnc] solved this issue for me :
param8=-SecurityTypes
param9=None
QWasson
  • 191
Dont install lastest version of xrdp. This problem happens with new version of xrdp
I face this problem too and I want to contribute so I made this comment, I fixed this by following commands:
sudo apt-get remove xrdp vnc4server tightvncserver
sudo apt-get install tightvncserver
sudo service xrdp restart
Login with Remote desktop connection from windows or with Linux you can use Rdesktop or anything you want then it should work.
After updating the file sesman.ini as indicated by Qwasson, execute:
sudo /usr/sbin/xrdp-sesman
abpi
Do the following - confirm xrdp was updated:
# sudo cat /var/log/apt/history.log
Re-install xrdp with this version:
# sudo apt-get install xrdp=0.6.1-2
Re-start xrdp:
# sudo service xrdp restart
It should work!
Jacman
  • 125
The answer from QWassan above is on the right path. Following the ubuntu bug tracker link referenced one can find a update (entry #15) to address the xrdp issue. I have applied the update / fix / patch to two systems now and both were successful allowing access to ubuntu systems via MS Win 10 remote desktop.
0.6.1-2ubuntu0.3 package works well on fresh 16.04 install. Confirmed a local connection to the vnc server prompts for password now.
wget https://launchpad.net/~ubuntu-security-proposed/+archive/ubuntu/ppa/+build/16288483/+files/xrdp_0.6.1-2ubuntu0.3_amd64.deb
aptitude purge xrdp
dpkg -i xrdp_0.6.1-2ubuntu0.3_amd64.deb
aptitude install vnc4server
