I'm using a Dell laptop with Ubuntu 16.04 LTS.
I tried to make a bootable USB after downloading the Windows 10 ISO file, but it doesn't appear as an option in the UEFI bootable screen.
I didn't use woeusb or any other program as I couldn't install them. I just made it using the Disks utility, then I formatted it as FAT32 then used **Restore Disk Image and restored the Windows ISO file. Is this a correct method of making a bootable USB?
Zanna
  • 72,312
Cloning works with Ubuntu iso files but it does not work with Windows 10 iso files. You must use some other tool, for example mkusb (if you have an iso file downloaded from Microsoft), or woeusb (if you have a custom iso file where the file install.wim exceeds 4 GiB).
  • Install mkusb into your Ubuntu according to the following link,
    help.ubuntu.com/community/mkusb
    sudo add-apt-repository universe  # only for live standard Ubuntu
    sudo add-apt-repository ppa:mkusb/ppa  # and press Enter
    sudo apt-get update
    sudo apt-get install mkusb mkusb-nox usb-pack-efi
  • Install woeusb into your Ubuntu and run it according to the following link,
    WoeUSB Error Code 256 with NTFS formatted USB
sudodus
  • 47,684
