On ubuntu 18.04, when I run sudo apt install simple-scan I get:
The following packages have unmet dependencies.
simple-scan : Depends: libsane1 (>= 1.0.24) but it is not going to be installed
I've seen others have had similar problems with broken packages but everything I've tried hasn't worked. Both sudo dpkg --configure -a and dpkg --get-selections | grep hold return nothing. However, sudo apt-get dist-upgrade outputs this, if it helps:
The following packages have been kept back:
colord
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
I think I had used a PPA for simple-scan in the past but I'm pretty sure I have no PPAs now.
EDIT: In response to user535733's comment:
$ sudo apt-cache policy simple-scan
simple-scan:
Installed: (none)
Candidate: 3.28.0-0ubuntu1
Version table:
3.28.0-0ubuntu1 500
500 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
$ sudo apt-cache policy libsane1
libsane1:
Installed: (none)
Candidate: 1.0.27-1~experimental3ubuntu2
Version table:
1.0.27-1~experimental3ubuntu2 500
EDIT: And Organic Marble's comment:
$ sudo apt-cache policy colord
colord:
Installed: 1.2.12-1ubuntu1
Candidate: 1.3.3-2build1
Version table:
1.3.3-2build1 500
*** 1.2.12-1ubuntu1 100
100 /var/lib/dpkg/status
EDIT: Attempting to install libsane1 fails with:
$ sudo apt install libsane1
Reading package lists... Done
Building dependency tree
libsane1 : Depends: libsane-common (= 1.0.27-1~experimental3ubuntu2) but 1.0.27+git20180317-xenial0 is to be installed
