I faced a strange issue with my Ubuntu 18.04. I use openfortivpn to connect to my company resources and it worked OK. I also use openvpn to connect to some different resources as well, sometimes even simultaneously. Today all resources behind the vpn became unreachable and I figured out this is related to some DNS settings on my PC.
With no active openfortivpn connection:
ll /etc/resolv.conf
lrwxrwxrwx 1 root root 37 Jan 9 10:52 /etc/resolv.conf -> /run/systemd/resolve/stub-resolv.conf
grep name /run/systemd/resolve/*.conf
/run/systemd/resolve/resolv.conf:nameserver 192.168.139.2
/run/systemd/resolve/stub-resolv.conf:nameserver 127.0.0.53
With active openfortivpn:
ll /etc/resolv.conf
stub-resolv.conf:nameserver 10.220.64.161
stub-resolv.conf:nameserver 10.220.64.162
As you can see, the openfortivpn has inserted 2 new nameservers into the /run/systemd/resolve/stub-resolv.conf which is fine.
But seems like the systemd-resolve doesn't take this new config (no DNS server for ppp0 interface) and internal resources behind the VPN were not reachable:
sudo systemd-resolve --status
Global
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
168.192.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 6 (ppp0)
Current Scopes: none
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
DNSSEC supported: no
Link 2 (ens33)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 192.168.139.2
DNS Domain: localdomain
So I tried to add the DNS manually into the systemd-resolve:
sudo systemd-resolve --set-dns=10.220.64.161 --set-domain=localdomain --set-llmnr=yes --set-mdns=no --set-dnssec=no --interface=ppp0
Global
16.172.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 6 (ppp0)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 10.220.64.161
Link 2 (ens33)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
And finally it works.
Any idea what is the problem here? Isn't this somehow related to openvpn-systemd-resolved because I can remember I installed this package recently in order to be able to use my other openvpn connections.
Thank you a lot for any advice. Michal.
