TLDR: I am running Ubuntu 18.04 with i3 and I messed up my permissions. Whenever I run a command with sudo, I get this error message, sudo: /usr/local/bin/sudo must be owned by uid 0 and have the setuid bit set. I am trying to figure out if I need to fully re-install Ubuntu or if this can be fixed in a less drastic way.
What had happened was: I was trying to upgrade my npm version with nvm and the nvm command was not being recognized. I followed this stackoverflow post's instructions https://stackoverflow.com/questions/21215059/cant-use-nvm-from-root-or-sudo to copy the version of node I had active via nvm into the /usr/local. I ran the below. (Yes, I realize now that I should have investigated this series of commands before running them.)
n=$(which node); \
n=${n%/bin/node}; \
chmod -R 755 $n/bin/*; \
sudo cp -r $n/{bin,lib,share} /usr/local
I then got tons of errors saying
chmod: changing permissions of '/usr/bin/*': Operation not permitted
After that I ran sudo nvm install-latest-npm and got the same error as I had before, sudo: nvm: command not found.
Then I tried running another command with sudo, and got the error sudo: /usr/local/bin/sudo must be owned by uid 0 and have the setuid bit set. I now get this error whenever I run anything with sudo.
I think this problem was caused by me running chmod -R 755 $n/bin/*; \ but I'm confused because the error message said permissions for /usr/bin were not changed.
I have a two-part question:
1) What caused this error? Am I correct that it was caused by the chmod -R command?
2) Can I fix this without completely reinstalling ubuntu? If so, how?
For context, I already read these two questions sudo: /usr/lib/sudo/sudoers.so must be owned by uid 0 and this /usr/bin/sudo must be owned by uid 0 and have the setuid bit set. However, I am not sure if the advice from the first question's answer applies to this situation, because the error message I receive is not referring specifically to /usr/lib/sudo/sudoers.so.
Thanks for reading!
