I'm a huge fan of Ubuntu, and I have been using it as my main OS for about 2 years now. I never had any issues with it until now when I have to dual boot (work requirement) with Windows.
I followed a guide how to install Ubuntu, and Windows and took the decision so simply start from scratch as it seems easier (since all guides said I should start with installing Windows).
So, I got myself another SSD (I want to have Windows on one and Ubuntu on the other one. I then started to install on sdb, so far so good, Windows starts fine. It created an EFI drive, and a system, etc. Whatever Windows needs.
However, now I wanted to install Ubunutu 18.10 on my PC on my other SSD. I created a USB installer and followed the normal steps until I came to pick drives, there I picked "Something Else" (I think that is what is it called) and re-portioned my other SSD (sdc) so half of it was the OS, and the other half my home folder. For the boot drive I have tried picking (sda, sdb and sdc), however, whenever I pick another drive than the Windows EFI drive as first boot option, I get straight into grub-rescue and can't do anything. :( If I move back over to making the Windows EFI drive, I get straight into windows and all works fine. I tried re-installing Ubunutu over and over again with different options but nothing worked.
Could someone explain the installation process to me like I'm 3 years old and can't even start the PC without my parents clicking the on-button? Because I just can't get it too work, and I miss having Linux as my main OS, I only want to boot in to Windows when I work from home, not always.
I'm not sure I understand all the options with /, /home, /boot, and the swap, EFI etc. when I create new drives.
sda = A regular HDD, 2 tb that I have partioned so 500 gig is for windows, and the rest I would like to partion as a second "home" drive for Ubuntu, that mounts automatically when I start Ubuntu, however, I have never figured out which option I need to pick for this one? sdb = Windows drive and all the folders it automatically creates when installing the OS. sdc = My other SSD where I want to have my /(OS), /home and SWAP.
However, like I said, I just can't get it working and I would really love any help at all to learn more about this and what it all means. I have tried reading several tutorials, but I just don't get it. :(
Update 1 It seems Ubuntu does NOT install in UEFI mode but in Legacy, and windows is installed in UEFI mode, how do I change this for Ubuntu when installing? The USB is also a UEFI (I turned of Legacy mode completely in my motherboard settings), but for some Ubuntu and Grub just won't work... – Zero just now edit
Thanks in advance!
/ is your root partition: main directory for your Ubuntu
/home is a user folder, it will be created anyway
/boot is a partitions where grub will be placed, should be primary
swap is for memory, same size as RAM, useful for hibernation.
G.H.
You were on the right track. A system can only have one EFI partition, and this is where the boot files go for all operating systems on the machine.
So do just what you had done, but let Ubuntu share the EFI partition with Windows.
Sturge
  • 131
